View Full Version : No Fob
maiahsdad
12-14-12, 07:03 PM
I have replaced the battery in my key fob twice now. About every other time I go to my car, I can't pull the handle and get in. It's not recognizing the fob for some reason. And, I'm either standing at the car, or I'm sitting in the car. When I arrive at a destination, it says the same thing. Are there any tricks to try and cure this?
1BadCadSTS
12-14-12, 07:11 PM
Is it in tr same pocket as your phone?
maiahsdad
12-14-12, 07:13 PM
Yep. Sometimes. But when I stop the car, it says "no fobs detected". It's not an every time occurrence. And the fob is not in my pocket with my phone every time.
dannyquest
12-14-12, 08:28 PM
maiahsdad, My 06 STS with nav, Reprogram all you setting in your nav just by turning off and back on. Worked for me. That was about 8 month.
maiahsdad
12-14-12, 08:51 PM
What exactly am I turning off, and then back on? And how?
dannyquest
12-14-12, 11:42 PM
maiahsdad, On you nav screen, turn off and on all your personal setting, seat, door lock , steering. Some time your computer will loses it mind. Its like a reboot. Pulling the battery cable will not work.Danny
EChas3
12-15-12, 07:40 PM
^^^ This doesn't match with my experience.
For system reset procedure, the disconnected battery cables should be briefly touched together. For me, that's worked better than pulling the Nav/Radio fuse. It resets all the car's systems, including the transmission control module (i.e. relearns optimum shift points for the style of driving style.)
dannyquest
12-16-12, 12:35 AM
Echase3, I didn't pull the fuse. Just went on the nav screen and toggled all the setting. At the time I didn't know there was system reset procedure. Thanks for the info. Danny
dkozloski
12-16-12, 01:34 PM
It sounds like RFI to me. Turn your phone off the hext time it happens and see if it makes a difference. Put the fob in the pocket in the console and see is it's recognized there. Let us know the results.
maiahsdad
12-16-12, 07:35 PM
When ever the problem has occurred, I've always been able to physically use the key fobs to unlock the doors, and then I have to put the fob in the console bypass pocket to make the car start. It is always started that way.
jdelp
12-17-12, 09:04 AM
Not sure if this will be any help whatsoever to your issue, but I've had a couple of instances where I would get the "no fob detected." Even putting the fob in the console pocket did nothing. In both cases I jumped the battery and it rectified the issue...this seems to happen after I have had the engine off, but acc. on listening to the radio - seems to run the battery down VERY quickly.
dkozloski
12-17-12, 09:57 AM
Does it do it with both fobs?
EChas3
12-17-12, 07:55 PM
These cars demand high quality batteries in excellent condition. Anything less will disappoint.
