: 05 cts-v need help with headlight info
J21sears
12-06-12, 03:53 PM
My passenger lowbeam/running light went out and I need to know what kind of bulb to replace it with. It's the stock 05 cts-v headlight
etcts-v
12-06-12, 05:45 PM
The lowbeam headlight or the tiny little running bulb in the bottom corner?
The lowbeam is D1S HID bulb that little bulb in the corner is a 194
For future reference, this website is always helpful. https://www.sylvania.com/en-us/applications/automotive-lighting-systems/Pages/lrgmain.aspx
J21sears
12-07-12, 08:20 AM
It's the low beam, and thank you appreciate it. Also would you know around what price range they run?
etcts-v
12-07-12, 03:42 PM
If you go with China brand you can buy 2 for $22: http://www.ebay.com/itm/Free-Shipping-12V-Xenon-HID-Conversion-Replace-Bulb-D1S-4300K-/321033909386?pt=Motors_Car_Truck_Parts_Accessories&hash=item4abf1cb48a&vxp=mtr
Here is a US seller: http://www.ebay.com/itm/HID-XENON-HEADLIGHT-D1S-4300K-X-1-BULB-STOCK-COLOR-HIGH-INTENSITY-DISCHARGE-35W-/160670678305?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ACadillac%7CModel%3ACTS&hash=item2568b7fd21&vxp=mtr
Or if you want Factory, the part number is 25735603
E-bay Factory: http://www.ebay.com/itm/ACDelco-D1S-factory-replacement-headlight-bulb-GM-25735603-BU4-/310490862711?pt=Motors_Car_Truck_Parts_Accessories&hash=item484ab29477&vxp=mtr
At GM Parts Direct the factory bulb is selling for $150: http://www.gmpartsdirect.com/
I'm fairly certain factory color is 4300k but someone like Fuzzylogic would know for sure, or a quick google search.
kerberos
12-08-12, 10:12 AM
Are you sure its the bulb and not the ballast?
J21sears
12-08-12, 07:49 PM
I am not 100 percent sure how would I be able to tell which one it is?
FoD
12-08-12, 08:15 PM
Easiest way is to change the bulb. If it doesn't work, ballast it is.
J21sears
12-11-12, 08:18 PM
So about ordering the 29.99 from the us seller are they pretty reliable like just as good as if I got them for 99.99 here at like auto zone or something
fej
12-12-12, 02:17 AM
Kind of a side note question, but can you upgrade the wattage of the stock bulb without making any other changes?
Thanks
Fej
Andringa
12-12-12, 03:35 PM
Thanks
Fej
I think that you would need to upgrade the ballast. I don't think that simply putting a higher wattage HID bulb would have great results with the stock ballast. But that is just a guess.
kerberos
12-12-12, 07:39 PM
Thanks
Fej
Are you looking for a brighter output, or different color? From what i've read, putting a 55w bulb with a 35w ballast will either be slightly brighter or have issues. Seems to boil down to the bulb and whether or not if its true 55w or something in the 35-45 range. To my understanding, most aftermarket 55w bulbs are not true 55w, but close. It also depends on the ballast, but I would think ours is fairly decent in comparison to what most people slap on their cars. One thing that seemed consistent is that if works the bulb life will be dramatically reduced. If you want more light, just put HID's in the fogs. Easy, cheap, and looks great.
JDB
12-13-12, 12:12 PM
Pull the driver's bulb and put it in the passenger side. If it turns on, it's the bulb.
fej
12-13-12, 12:20 PM
I am always looking for more light output on my cars, and in this case as close to stock color as possible for higher lumens. I am going to have to research the HID fogs and try and do some cleanup on my current headlight lenses to see how much better I can get them.
Thanks
Fej
etcts-v
12-14-12, 04:09 PM
Thanks
Fej
Upgrade to aftermarket ballasts and bulbs, ddm has a 55watt kit. Also do one of those headlight restore kits, they work like a charm especially if you have a machine polisher.
