: Left turn traction control, breaks not fully releasing
nomadgj
12-04-12, 10:26 AM
I have an 03 ext bought new, 125,000m. Everything is starting to fall apart. instrument pannel, bearings,cat. converters, driving me nuts. The new thing now is traction control activates when I turn wheel tight to left at low speeds,backing up, slow turns. .Is there a sensor in the hub and does it have to be replaced or is it possible it may be a loose connection. Also my breaks are not releasing completly. I bled the calipers and they release. It must be an abs issue the light comes on now and then. I know very little about this. Any thing I can check Any help is appreciated. nomadgj
the cadillac man
12-04-12, 10:49 AM
Wheel hub has a speed sensor in it so it will need replacing
nomadgj
12-04-12, 07:56 PM
Ok I'll look into that hope it won't be too pricy. Thanks for the response.
