: Musty "Odor" smell when the windsheid defroster is turned on
classiccars
12-03-12, 09:00 AM
My wife's 2012 SRX has (had) a musty odor coming from the defroster vents when it was turned on. Has anyone else had this problem? Is it a problem or normal? What was the cause?
Thanks
Jake2010
12-03-12, 09:12 AM
I had a musty/bad odor coming from my 2010 when A/C went on (I think the defroster will cycle the A/C also). But anyway, I changed the cabin air filter and it took care of the problem. The car had around 16k miles on it at the time. I was surprised the cabin filter was as dirty as it was, so I think it's doing it's job!
It's an easy install, you can do it yourself for around 15 bucks!
classiccars
12-03-12, 12:27 PM
OK, So I started searching ebay for any new Cabin Filter deals. Some are saying that the 2010-2011 filters are not the same as the 2012 and/or the 2013. I would think these are all the same between the four years. Is part number: 13271191 correct for the 2012 SRX?
brs332
12-07-12, 06:07 PM
Thanks
Lysol via the cabin air intake sometimes does the trick, too.
Brian.
