View Full Version : Engine "missing" during acceleration STS 310 12-21-04, 04:05 PM Was just every now and then but, this is starting happen more often. At acceleration, seems that a cylinder is not firing properly. This only happens at acceleration at low rpm. There is no "popping" to indicate a misfire and there have been no codes set.
On the highway it runs great with no hesitation.
Engine has 55k miles.
Any ideas? Let me take a wild guess here. Did you just have your fuel rail changed? I and many others have had the same problem right after the rail change. Two words........ PLUG WIRES. STS 310 12-22-04, 12:34 PM No, I have been lagging on the recall. Plug wires would still be my first guess. peteski 12-23-04, 01:42 AM All those computerized engines we have nowadays... Don't you just love it. They take care of themselves. :D
Give it another 10 years and the cars will be telling you how to drive them. Also the "big brother" will be monitoring all your moves and report back to the government!
Seems that devices are getting smarter and humans are getting dumber. Robots were supposed to take over teh Earth in the 21st century. We have no robots (as in machines who look like humans). But the real robots we have are actually cars, washing machines, cell phones, PCs, etc. Our appliances. And they are sure getting "smarter". So, it looks like our robotic appliances will be taking over the world...
Peteski
:lildevil: ellives 12-23-04, 08:25 AM All those computerized engines we have nowadays... Don't you just love it. They take care of themselves. :D
Peteski
:lildevil:
Hmm -- might we be a little paranoid?
I'd vote for the plug wires too.. easy job - and can't hurt -- and will eventually need to be done... the next pick would be the fuel pressure regulator
Ells STS 310 12-23-04, 06:29 PM Hmm -- might we be a little paranoid?
Ells
Would these things cause this problem even in neutral? Like I said, sometimes everything runs purrfect. And sometimes its sputtering like a jalopy. dkozloski 12-23-04, 07:27 PM A pilot wrote up an aircraft as the number 2 engine was missing. The pilot cleared the problem by replying "Engine found on wing after brief search". ellives 12-23-04, 08:00 PM Would these things cause this problem even in neutral? Like I said, sometimes everything runs purrfect. And sometimes its sputtering like a jalopy.
Absolutely.... my '97 STS was doing exactly that when I decided to replace the plugs and wires. Runs smooth as silk now.... 94K miles... woohoo
Ells And I thought it was the mechanic that found the missing engine.!! sts96 Would these things cause this problem even in neutral? Like I said, sometimes everything runs purrfect. And sometimes its sputtering like a jalopy.
Mine idled just fine. Cruised just fine. WOT ok as well. but light acceleration, ran like shit! 93greeneldo 12-24-04, 05:14 PM same here i needed new plug wires and plugs on my 98 eldorado. mine was fine when cold but as it warmed up it started to miss and run bad just like yours especially at low rpm's Mine does the same thing and it's got a new set of wires and plugs on it STS 310 12-25-04, 05:11 PM Mine idled just fine. Cruised just fine. WOT ok as well. but light acceleration, ran like shit!
Exactly Ranger. So plugs and wires was the remedy. Actually wires was the remedy. Plugs were due. Most of the platinum tips were gone and consequently the gaps were .65 -.70 but that did not fix the problem. Got OEM wires from http://www.rockauto.com/ for $116 + shipping ($122). Runs like it used to now. STS 310 12-25-04, 08:51 PM Well Ill start with the wires and see where that takes me. peteski 12-27-04, 01:18 AM Hmm -- might we be a little paranoid?
Ells
My comment was tongue-in-cheek (for most part...)
:D
Peteski |
