: Stream Your Music Wirelessly over Bluetooth
Royalton
11-25-12, 10:58 PM
Hey guys here's a project that I am in the middle of that I would like to share with you all:
Our vehicles have bluetooth for calls but they lack the ability of streaming music. (shows how dated this model year is)
Step 1: Buy a bluetooth receiver. It is a small box available from amazon or bestbuy it is meant to stream from your phone to your home stereo.
This is the device that I bought, it is a slightly bigger than some of the others but got the best reviews and I dont need to purchase a phono to rca adapter cable
http://www.amazon.com/gp/product/B004VM1T5S/ref=oh_details_o01_s00_i00
100436
Step 2: You need to purchase a step down voltage regulator since we want to take our cars regular 12v down to 5v.
This is the one that I went with. other options are a 5v resistor from radio shack or buying a phone charger or one of those cheap usb port chargers. if you do that than you will need to take it apart and wire it yourself, but at least those provide the correct voltage
http://www.amazon.com/gp/product/B00A71CMDU/ref=oh_details_o00_s00_i00
100437
(This is the point I am up to so far)
Step 3: In the rear end of the center console where the rca inputs are, open up the cup holder and unscrew the 2 screws that are closest to the top. pull up and out and that whole panel will pop off. Here is where you splice into a power wire to power up our bluetooth unit. you will cut the cord that came with the unit and hardwire it in here, making sure to use the step down power converter. There MIGHT be a 5v cable in here but I am not sure I have not tested any yet, its doubtfull though so thats why I purchased the step down anyway.
Step 4: Here you have 2 options cut the cars rca cables and splice them into another rca cable and plug that into the bluetooth unit. OR get a regular stereo rca cable, plug one end into the blue tooth unit and the other in to the back or center console, your choice. I am splicing mine because I dont like cables hanging out in the rear.
I think there is enough room inside the empty space of the rear panel that we pulled off for the step down and the bluetooth box. If there is not than I will mount it under a seat
There you have it after this you will be able to wirelessly stream your music and pandora right from your cell phone to your trucks sound system
Install pics to come soon.
Patradamus7
11-26-12, 04:51 PM
Wow Very Nice!! How does it sound? When I used the rear RCA's plugged into my iphone the sound wasn't nearly as good as a CD to a point I didn't even want to use it.
sparsons79
11-26-12, 06:36 PM
Please post pics...sounds awesome! I currently have the Apple RCA cables plugged in with a $12 bluetooth connection that works with my phone, but would like to get rid of the cable hanging out of the back of the console on the floor.
100436
100437
Install pics to come soon.[COLOR="Silver"]
Patradamus7
11-27-12, 12:30 AM
Sparsons79. What Bluetooth module are you using? Is it hardwired?
Thanks
lee88
11-27-12, 02:49 AM
Maybe there's something wrong with your aux cord because I use mine for my iPhone as well and it sounds crystal clear.
Just a thought
Royalton
11-27-12, 05:31 AM
Use a different cable, It should be perfect sounding. For some reason it is very picky about using a good quality cable. I tried an old cheapy and sounded like a bad ground, switched it to a nice insulated gold plated one and sounds perfect.
Also for those of you asking the blue tooth also sounds CD quality. Bluetooth profiles have come a long way in the past few years. I believe it sends 160hrz compression which is high. higher than a regualar mp3 file
Patradamus7
11-27-12, 09:48 AM
Can anyone give me a link to the exact iPhone cables you are using? I was using genuine Apple cables for my iphone and I I have also tried a couple other pairs of high end cables and the mids and highs are completely clipped like I am listening to a 128 kbps mp3 even though they of course aren't.
Thanks!
Royalton
11-27-12, 11:42 AM
Did you try a different device? or turning the device volume up higher and the car stereo volume lower? I connect to my gallaxy s3 phone and always have that volume to the max and my cars volume up just a tad.
Patradamus7
11-27-12, 11:43 PM
I have tried different volumes and settings on the phone and dash. Can't get it to sound good. I have a lot of experience in dabbling with audio at home and car so I am by no means an amateur at this but I can't believe I am the only one who doesn't have good quality music from the rear aux. Any other tips? Thanks!
Royalton
12-13-12, 12:29 PM
101126
All finished. I cut the power outlet cord and spliced in my 12 to 5v volt step, than cut the power cord to my bluetooth receiver. I decided not to splice the rca cables so I unscrewed the little rca outlet box and connected to it regularly and kept that inside now. I may get a dummy rca outlet replacement off another car just for show, right now I taped up the back of the holes so you dont even notice that they are missing.
There is plenty of space behind the rear console panel for everything and then some. it fit back on perfect. When I'm in the car I just connect to logictech bluetooth, have my radio on aux and wahla I can now stream music from my phone to my car. The quality sounds 100% perfect. My girlfriend even said it sounded better than before.... but what does she know, she's a chick ;) doesn't sound better but sounds exactly the same as plugging in.
oh if you're asking why I taped up the sides of the bluetooth receiver, that was just to make sure if wouldn't make any noise while going over bumps, since it's not exactly mounted or anything.
Patradamus7
12-15-12, 01:10 AM
Wow very nice !!
Escapade
12-15-12, 04:13 AM
Thanks!
Apple Store. Apple branded VGA cable should work just fine. Belkin brand is good too.
anhandrew
12-18-12, 02:28 PM
I have a question. How do you pair the phone to the unit it if is hidden? Does it lose the pairing when the car turns off? That bluetooth unit pairing button is on the unit is it not?
Royalton
12-18-12, 09:35 PM
It will depend on what bluetooth receiver you buy. The one I purchased will remember all paired devices even if the power is unplugged. The wire I tapped into though is for the cigarette lighter so my unit stays on always. I paired my phones my gf phone and ipads to it. In the future if I get a new phone I will have to reopen up the back, to pair my new device to it. But by this time comes around I will find a bluetooth receiver that you don't need to push a button on it to pair it, and I will replace it with that one. So far no luck though as they all require a button to be pushed for pairing
beav626
12-19-12, 08:17 AM
WOW great idea!
whatname
02-22-14, 12:05 PM
Are you still able to use the rear cig lighter to power devices? You state that the unit is always on, do you have any battery drain issues?
jamaicanborn
02-22-14, 05:56 PM
This is great news. I have a 2010 ESV and would love to add this feature. Cant wait to see some pics. Thanks
beav626
02-23-14, 10:33 AM
I have something similar to this in my center storage, but I have to sync to it everytime I get in the truck. Does your method sync automatically?
I have a Samsung galaxy s3
CaMs
03-19-14, 01:05 PM
nice.. just seen this post.. great idea.. might due this, this weekend
Mikes07
03-19-14, 06:39 PM
Great write up!!
Mackda600
03-21-14, 03:18 PM
Great write up. I just did the same thing with this part from Amazon:
http://www.amazon.com/gp/aw/d/B00BYGEVA4
Hit everything under the center console, no bluetooth code auto finds/connects.
I did however have to install a ground loop isolator to cancel out the noise. Everything working GREAT!
ycharris
03-04-15, 02:31 PM
Motorola Roadster 2 tz710 Bluetooth Speaker, anyone tried this
gloz28
03-04-15, 05:40 PM
Lord yes haha who has any idea what I can buy to put Bluetooth in my esky because i have a 2007 and it doesn't have Bluetooth or an aux input
vagoldenboy
10-15-15, 10:30 PM
Thank you for the link. I just set this up, and it worked flawlessly.
beav626
10-16-15, 09:08 AM
I recently sold my truck and have the above amazon dongle and power stepper that I am not using. IF anyone wants this kit, $20 and its yours.
denaliguy
10-16-15, 11:02 PM
beav626, I'm interested. I tried to send you a PM but it says you cannot receive them. Can you try sending me one?
beav626
10-16-15, 11:24 PM
PM Sent and I updated my setting to recieve PM's
Raulie
02-10-16, 01:23 AM
Maybe this is a dumb question. Does this connection interfere with the phone call bluetooth over the onstar connection? Does it conect to both? Phone and media stream?
beav626
02-10-16, 09:20 AM
What is your device? Most Android Phones can connect to multiple devices and distinguish between a media player and a phone system. My Samsung devices connected to both the car Bluetooth and my new adapter for streaming. If I'm streaming music and a call comes in, the car would pick it up like normal.
Now the Onstar is a completely different system and doesn't connect using Bluetooth.
whatname
02-17-16, 02:41 PM
Does anyone know a good location of a 12v supply and ground other than the cig lighter? I am looking for a source near the rear RCA inputs that would turn off with the vehicle so i dont run the battery down.
beav626
02-17-16, 02:47 PM
your best bet is to run a wire to the fuse block in the driver foot well to a source there. The wire can be run under the carpet through the normal slits
ThaDoctor72
06-24-16, 09:14 AM
That's a neat idea. I did the same thing with a Raspberry Pi, but your solution looks less archaic than mine.
gdholt74
11-22-16, 05:13 PM
this is a great tutorial. If the thread was updated for new hardware (since original post was 2012), what would be the suggestions?
thanks.
tmonee98
02-08-17, 03:10 PM
thanks.
I ordered this
https://www.amazon.com/gp/product/B016NUTG5K/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
and this
https://www.amazon.com/gp/product/B00CXKBJI2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Should be able to install this weekend. Just picked up my 09 Escalade
estreetgt
02-08-17, 03:43 PM
Funny I was just planning to post similar.
Logitech has a newer model of the bluetooth receiver, found it on amazon
https://www.amazon.com/gp/product/B00IQBSW28/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
Bought the 12-5v step down also on amazon
https://www.amazon.com/gp/product/B00CXKBJI2/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
I took it a step further and picked up an RCA to speaker wire adaptor, amazon
https://www.amazon.com/gp/product/B00I4EBOYK/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
For power I used the cig lighter like the OP did. If leaving on is a concern I'd either add a switch or find a different power source. Eventually, I might but for now this works.
For the RCA adapter, I REALLY wanted to retain the OEM RCA ports. I spliced the speaker wire adapter into the stock plug wires. It's the yellow and white wires on the plug, ground is common and it's the bare wire bundled with the yellow and white. I did right channel of the harness to yellow and left to white, twisted the grounds together on the bare wire and it works perfectly.
I did try this for a few weeks using the OEM RCA ports and an RCA to 3.5mm cord, this setup had lots of signal noise. I put a ground loop isolator in it and that resolved the signal noise. With the RCA speaker adapter splice outlined above, I have no signal noise without the isolator. YMMV.
