View Full Version : T56 Bandaids Prepped - Ready to Rock!
FuzzyLogic
11-24-12, 01:32 AM
http://img.photobucket.com/albums/v219/QuicksilverG4/CTS-V/IMG_0292.jpg
Parts List:
PISNUOFF delrin/steel center linkage bushing (shifter side)
UUC polyurethane side linkage bushings (shifter side)
Azn2dmax fabricated center linkage arm
B-Quiet Ultimate damper to eliminate vibration in all three linkage arms
PISNUOFF brass center linkage bushing (T56 side)
Home Depot PVC side linkage bushings (T56 side)
Tremec #95 T56 bronze isolator cup
Tremec #52 T56 shift detent spring
Tremec #53 T56 shift detent ball
Carriage bolt
If this doesn't result in a night and day difference in shift quality, I'll eat my socks. Stay tuned!
Credit to Cadzilla for starting this whole thing (http://ls1tech.com/forums/cadillac-cts-v/1517800-b-m-shifter.html) and PISNUOFF and Azn2dmax for fabricating extra parts that you can't get anywhere else.
mdleal
11-24-12, 03:14 PM
About how much do you have invested?
FuzzyLogic
11-24-12, 03:28 PM
In this mod alone? About $125, not counting the second generation Katech short shifter that I installed two years ago.
etcts-v
11-24-12, 04:50 PM
What does the Tremec spring and Ball fix? I missed those when I did all the upgrades!
FuzzyLogic
11-24-12, 06:37 PM
Look up the Anti-venom mod for the T56. The detent assembly utilizes a captured ball and spring to give you that tactile "notch" going in and out of gears. The force required to push past that ball and spring is dependent on the strength of the spring, the condition of the ball, and (mostly) on the length of your shifter. Most people complain about the additional force required to shift following the installation of a short shifter, but they don't understand what's causing that other than the obvious loss of leverage. Now you do.
Most of the time, when people complain about trouble shifting, the root of the problem is a transmission-motor misalignment (sagging motor mounts anyone?), but if they have a really short shifter, sometimes you really need to recalibrate the strength of the detent assembly by shimming it with one or two copper 13/16" washers. Finding a lighter spring really isn't an option, unfortunately, since the spring is an odd size. In some rare cases, that captive ball has gotten corroded or otherwise jammed in the assembly and won't spin any longer, which makes it even harder to shift than Tremec intended with the stock shifter assembly length. Emphasis on "rare." Since the parts are cheap, I figured I'd get in there and replace them while I have the transmission down.
By the way, I'm sure I don't need to remind you, but take the opinions you'll find on the Anti-venom mod with a huge grain of salt. Some of the people that are reporting success are masking major transmission misalignments, and some of the people that are indifferent or entirely pooh-pooh this mod have stock length shifters. This is truly one of those situations where the statement, "your results may vary" truly applies.
Mn800r
11-24-12, 09:37 PM
:rockon:: just ordered all revshift makes for the V but the flex disc, will follow this for sure as my shifting is not how i want it,hope all works out, keep pics and posts coming please.
sssnake
11-28-12, 04:52 PM
I assume the B-Quiet is to reduce shifter rattle. I now have a few pieces of RAAM mat on mine. It helps.
Mn800r
12-06-12, 10:16 PM
Parts List:
Carriage bolt
Are these in your parts pic?, if not where can a guy get some of these?
http://i248.photobucket.com/albums/gg181/ddfunhouse/CTS-V/9dbe2656.jpg
http://i248.photobucket.com/albums/gg181/ddfunhouse/CTS-V/56e35e8f.jpg
FuzzyLogic
12-07-12, 01:28 AM
Holy mother of .... ! You win the award for the most deteriorated shifter bushings ever. Here's where you get new ones:
https://creative-steel.com/store/index.php?l=product_detail&p=37
FoD
12-07-12, 01:05 PM
Seriously. Wow. Mine were bad, but nothing compared to yours. FYI, installation of the new bushings is a bitch without some sort of lube/grease.
Mn800r
12-08-12, 10:01 PM
Will do good to know, when I do the cradle,Trans,trailing arm and motor mounts they will go in at that time.
Faber
12-09-12, 09:28 AM
I did a few searches but the wife is getting on me to do some stuff around the house so I'm hoping you canhelp me out. Anyone have a picture of the bolt for the Anti-venom mod?
FuzzyLogic
12-09-12, 10:00 AM
Really? I typed "anti-venom mod" into Google and all kinds of images came up. Took five seconds.
http://i16.photobucket.com/albums/b36/roadstr6/t56arrow.jpg
Faber
12-10-12, 09:07 AM
Thanks for the pic - I was searching "Anti-venom T-56" and kept finding forum references but no good photos showing where it was at. This morning took out the "-" and the picture you showed popped up. Ah the nuances of searching...thanks for finding that and sorry for being tarded.
future_05_v
06-18-13, 11:41 AM
Has there been any other updates on this mod?!
jmsweetv
06-18-13, 12:29 PM
I will pay and handsome fee!!!!!!!!!!!!!
Those parts look awesome and remember reading some threads about the pvc side linkage.
Not to sound like an unappreciative impatient ***hole but i'm in when ya'll figure out price.
Wish I had the ability to come up with something awesome to contribute...other than money.
odthetruth
06-18-13, 12:42 PM
That center linkage arm wouldn't work. I'd bet money on that.
jmsweetv
06-18-13, 04:39 PM
Can you explain more? I'm getting ready to drop my tranny and am trying to get all the info I can to get that last bit of slop out.
odthetruth
06-19-13, 05:19 AM
Center linkage arm is too short from the first post. I wouldn't go that route with the linkage arm at all. Trust me. Everything else looks good.
FuzzyLogic
06-19-13, 06:25 PM
I'm on travel, so I don't have much time to write, but suffice it to say that the center linkage arm in my original picture is not required and would not fit anyway.
I wrote most of this up on the LS1Tech forums already, but to recap:
- Based on Cadzilla's original thread on LS1Tech, I subjected te center linkage pin to extreme scrutiny. On my shifter, the pin barely moved in its hole, so I did not feel that welding it in place was necessary.
- I replaced the plastic shifter cup with the #95 brass cup. Unless your cup is broken, it shouldn't have any effect on shifter slop. It is "merely" a durability upgrade.
- I also evaluated the "Anti-Venom" mod. After looking at the shifter detent assembly and experimenting with several copper crush washers, I came to the conclusion that any deviation from the stock design would result in very sloppy shifting characteristics. My detent ball and spring were in excellent condition. If yours is seized, I would buy a whole new assembly instead of just the ball and spring, since it's not obvious how to service the detent assembly. I looked and looked for instructions to no avail.
- The big two winners were the Home Depot mod and PISNUOFF's brass replacement bushing for the rear part of the center linkage arm. They really, really tightened up the shifter and added zero additional vibration. Advice: even though you only need four bushing pieces from Home Depot, buy 6-8. You'll find that their manufacturing tolerances result in some pieces that fit like a glove and others that are just a touch looser than you'd like. They're only like 48 cents apiece, so you can afford to buy a few extra. ;). Also, having a press on hand (e.g. a $30 bench vise) is very useful when it comes to jamming the metal cores from the stock rubber bushings into the PVC Home Depot bushings.
- The Creative Steel shifter bushings are terrible. Get the UUC ones from Luke @ Lindsay Cadillac. I bought a set of Creativr Steel ones in advance to compare to my old UUC bushings and was stunned at how poorly fabricated and soft the Creative Steel units were. They might actually be worse than stock!
jmsweetv
06-19-13, 06:45 PM
So you will or will not gather these parts along with instructions for my lazy a$$ once you testing is complete?
Nevermind, I guess I should have read the post all the way through. Thanks for the R&D! I already have Brian's shifter and center bushing along with the UUC bushings. I was hoping to try and clean up anything I could on the other end of the linkage.
FuzzyLogic
06-19-13, 10:30 PM
Assorted pictures below. Sorry for the lack of proper chronological documentation--it started raining and I just wanted to get the effing thing finished.
http://img.photobucket.com/albums/v219/QuicksilverG4/CTS-V/McLeodRXTandShifterInstall_zps2673cf2d.jpg
http://img.photobucket.com/albums/v219/QuicksilverG4/CTS-V/ShifterLinkageUpgrades4_zps902daacd.jpg
http://img.photobucket.com/albums/v219/QuicksilverG4/CTS-V/ShifterLinkageUpgrades3_zpse0350fc9.jpg
http://img.photobucket.com/albums/v219/QuicksilverG4/CTS-V/ShifterLinkageUpgrades2_zps85aa8e6e.jpg
Fresh OEM center rear linkage bushing (goes into base of shifter) vs 7 year old unit
http://img.photobucket.com/albums/v219/QuicksilverG4/CTS-V/ShifterLinkageUpgrades1_zps69f7e394.jpg
http://img.photobucket.com/albums/v219/QuicksilverG4/CTS-V/ShifterLinkageUpgrades5_zps8463591a.jpg
http://img.photobucket.com/albums/v219/QuicksilverG4/CTS-V/ShifterLinkageUpgrades6_zps0b342f5e.jpg
View into T56 shifter assembly with no plastic or brass #95 cup installed
http://img.photobucket.com/albums/v219/QuicksilverG4/CTS-V%20Linkage%20Bushing%20Measurements/OEMForwardLinkageBushingLength_zpsd6a5c089.jpg
Home Depot side front linkage rail bushings vs rubber OEM
http://img.photobucket.com/albums/v219/QuicksilverG4/CTS-V%20Linkage%20Bushing%20Measurements/High-LevelUUCandCreativeSteelComparison_zps62b2f565.jpg
UUC side rear linkage rail bushings (installed) versus Creative Steel
See these threads for a discussion of the pin and the brass PISNUOFF center bushing, plus everything else I talked about earlier:
http://ls1tech.com/forums/cadillac-cts-v/1517800-b-m-shifter-2.html
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-performance/246803-shifter-bushings-question.html#post2841048
