: Extended crank time- bad fuel pump?
Precisionmike
11-22-12, 12:23 PM
Happy Thanksgiving all!
I have a 2002 Escalade. When I try to start (regardless of how warm or cold the motor is), I have to hold the key to start for at least 3 seconds. If I release the key and try it a second time, it fires right up.
I have replace the fuel filter and fuel pressure regulator, no change. I do not have the tool to check the fuel pressure. My fear it a bad fuel pump. Is there anything else I should check? How hard is a fuel pump for a seasoned DIY? Thanks! Mike.
the cadillac man
11-22-12, 02:51 PM
You have to drop the tank and there are three lines and two harnesses that go to the pump
You can find YouTube videos of how to do this but I couldn't do for 2 reasons one my back and two I don't have the space or a lift to do the work
nsx24
11-24-12, 04:55 PM
You are correct about it being the fuel pump, ask me how I know. 2 fuel pumps in 20 months in my 03 Escalade. Both times starting out that it cranked a little longer, then took two times of cranking and then three before it finally died on me. I feel like a pro when it comes to changing so if you need any help let me know.
