: Catch can a must on DI motor
jbelot
11-18-12, 08:04 PM
If you donít have a catch can on your DI motor, get one! I installed mine at around 50,000km. Yesterday I installed my isolator and had to remove the top end of the motor. With a flash light I could look down the port and see my valves. They are coated black and flaking carbon chunks. I did an upper induction cleaning and oil change the weekend before so it may have been cleaner but I was absolutely shocked at what I saw. I couldnít get enough light down the hole to get a picture but Tracy has posted enough so you can get the idea.
As I said above I was installing the isolator this weekend and took the car for a boot this morning. It rips! What a change with such an easy and inexpensive mod. Iím a fan and advocate for RevXtreme. A wrench, couple of sockets, gasket material and a few hours is all it took.
I took a bunch of pictures, Iíll see if I can post them.
jbelot
11-19-12, 07:08 PM
Well my picture file is to big. I guess I should have taken the pictures with my phone. I will figure it out later.
reciprocity
11-20-12, 07:13 PM
If you have iPhoto or a similar photo editing program, you could export the photos at a different size using that. If not, there are online services like resize2mail (http://www.resize2mail.com) (never tried it before but it looks promising) that should allow you to downsize your photos pretty easily.
jbelot
11-21-12, 11:56 AM
That's what I need to do. I'll give it a shot later. Thanks!
jagi0966
11-22-12, 09:37 PM
Has anyone had a freezing issue with the catch can or extended lines? I expect the extended lines away from the heat of the engine will collect moisture and have potential to freeze up and not allow the engine to breathe.
SC2150
11-23-12, 05:55 PM
We have over 11,000 in use over the past 9 years and have had 1 customer in north dakota that had the valve freeze in subzero temps.....but that is the only issue we have heard of to date. It is important to drain with the engine warm, and not running and in cold climates all cans will condense and catch a good deal of moisture so they fill much faster. It will look like nestle quik!
:thumbsup:
jbelot
11-27-12, 01:00 AM
If the valve freezes, what issues should I be looking and listen for. I am in Canada and it gets darn cold here for a good 3-6 weeks. Thanks for the heads up on draining for the moisture when it`s colder!<
And once again. SC2150 makes great products. BUY THEM! I am not related at all, just a happy customer!
smithb
12-16-12, 10:17 AM
If you open the file in Paint, which I'm pretty sure every copy of Windows comes with, you can shrink the file size using Resize (I think it is called). Also, if you just open and resave it, Paint does a better job of compressing the file as a jpg.
JusJZ
12-22-12, 10:17 PM
How do you shrink on an iPhone?
jbelot
12-27-12, 02:47 PM
101642101637101638101639101640
jbelot
12-27-12, 02:55 PM
I finally took the time to put up these pics. Look at all that oil prior to the catch can. The throttle body was caked with oil. I did upgrade to the RX ported and polished TB and these pics where taken when I installed the RX Black isolator. This is why a catch can is a must. I wish I could have shown the valves, I felt sick when I took a flash light and looked down the ports. The valves are completely coated. I will be going through a cleaning regiment with every oil change until they are clean again.
I did the shrink through Piacsa 3 by exporting them to another file.
unitymixer
01-03-13, 05:05 PM
sorry to ask but, could you explain to me how it works ( for a Green like me) , how to oil return to the engine from the catch can.
thanks.
SC2150
01-03-13, 07:25 PM
You dont ever want to return the oil caught in a catchcan to the engine crankcase as it is chock full of damaging compounds (abrasive carbon particles, sulfuric acid, water vapor, unburnt fuel, etc.) The catchcan traps the oil before it ingests and causes the issues so the trapped oil is disposed of.
:thumbsup:
X E Ryder
01-03-13, 10:53 PM
I have asked which part number to order for a '12 coupe and not received a response.
Me <-- I'm a buyer, ready to purchase a catch can.
Why do some have single/double check valves etc?
SC2150
01-11-13, 04:19 PM
Sorry, just saw this post.
Single valve is for a NA application, dual for forced induction that pressurizes the IM.
Call us direct for any questions: 941-721-1826
You may have to leave a message, but we will get back to you.
:thumbsup:
X E Ryder
01-13-13, 10:44 PM
OK for anyone wondering if a 2012+ LFX motor needs the catch can, the answer is YES. Here is why I say so: :suspense:
I now have 930 miles on my coupe, I am properly breaking the motor in - I have NOT been over 4,000rpm (as directed until 1400 miles)
Today I pulled the PCV line for fun and guess what? I got 2 drips of oil out of the Intake fitting end of the line ALREADY! :mad2:
Just a light tap tap on my index finger and there is was, already! I looked into the Plenum with a LED light and you can see some nastiness too. :annoyed:
Anyhoo, the sooner you install a Separator into your PCV line, the longer you are extending your motor's longevity!
Pitchblack98
01-15-13, 12:42 AM
I was hoping to have a catch can on mine by now. I ordered a catch can and ice-olater from revxtreme over a month ago and still haven't received them.
SLICKNICK54
01-15-13, 11:19 AM
I want a catch can but previous member is still waiting from the extreme and they charge $15 shipping on top of $ 200 order? Where is best place to get from and do you need the vent cap ??
X E Ryder
01-15-13, 11:56 AM
I called and left messages and finally spoke ti a gal said he'd call me... Didn't happen. I want to deal with someone more accessible. Nothing personal, just my preference.
Anyway I went with the Moroso ordered from Jegs $143 shipped - the kit is for CTS V but has same 3/8" fittings as 3.6 needs. Black is # 85603 is memory serves.
SLICKNICK54
01-15-13, 11:59 AM
Did you get the breather cap to? Was shipping free with jegs?
X E Ryder
01-15-13, 01:51 PM
I'm not adding a breather cap, we already have the fresh air line to the system on the other side.
For the LFX they call it fresh air line (the PCV is labeled Foul air line in their service docs)
Not a fan of that addition myself, if we needed it, GM would have provided it - I don't like introducing another source of air (maybe condensate) into the crankcase. Obviously not all agree with this school of thought, but that's mine buddy. :)
tinman
01-15-13, 01:54 PM
As you said, "...if we needed it, GM would have provided it..." isn't exactly true. We do need the catch can, and GM did not provide it.
Not provoking or flaming, so don't take this wrong.
X E Ryder
01-15-13, 02:32 PM
Well they did give us a fresh air inlet, it's there, I'm not going to put in another one.
And none taken! :)
tinman
01-15-13, 02:43 PM
(chuckle an' snort)
jbelot
01-16-13, 11:38 AM
You replace the fresh air with the breather. The problem with the breather is it replaces the oil fill cap, the breather is about 2 1/2 inches tall and hits the hood creating big issues with fit. If you have an isolator installed the fit is worse so in my experience the stock fresh air is not worth trying to improve unless there is a very low profile product out there. The big advantage I believe in replacing the fresh air with a breather is eliminating the possibility of sucking oil vapours from the valve cover under full throttle. I know this happens, look at the picture of my TB above. It is full of oil deposits.
SC2150
01-16-13, 12:58 PM
Hi All,
I have been out sick with this dang flu (still am) but the cans can be ordered from the website: www.RevXtreme.com
or by calling direct: 941-721-1826.
The Moroso can looks great, but it lets 30-40% of the oil to pass through due to the design. Just take a clear glass inline fuel filter (app $10 from any autoparts store) and install it between the can and the IM and in a few hundred miles it will be staurated with the the oil it allows through.
It is far better than running no can though.
We are running app 3 weeks lead time now trying to meet the demand (have added new staff, etc.).
On the breather, the current one is to tall and were trying to source the element portion that is shorter, but so far no luck. We can make our own but the price would be to high so stay tuned....were still looking.
I'm delerious with fever right now if this dosent make sense, thats why.
:thumbsup:
HurstGN
01-16-13, 02:18 PM
I wonder if the new Stingray has a catch can from the factory. It has a direct injected engine, so it needs one. I can't imagine the Vette folks accepting that oil getting ingested in their motors. If GM decides to install a catch can anywhere, it will be on their flagship car. If not, then GM has fools for bean counters dictating the parts used.
Pitchblack98
01-16-13, 03:46 PM
Does that mean I'm going to have to wait 3 more weeks before I get my order? If so, I'd like a refund so I can order from somewhere else. I ordered a catch can and ice-olater 5 weeks ago... Still haven't received them or any answers to emails I've sent asking for a status on my order. That's $350 I'll send else where.
tinman
01-16-13, 03:59 PM
Call 'em. I didn't wait that long. I only ordered the can, and it was about 3 weeks or so.
Pitchblack98
01-16-13, 08:06 PM
I've tried calling and emailing a few times. I'm not going to keep calling until my order arrives. I'm too busy during the day at work and shouldn't have to...
jagi0966
01-16-13, 11:21 PM
What makes the DI version seem to need it? What damage is a little oil doing in the plenum?
It could lead to a little buildup on the back of valves, but it will end up in the cylinder where its burned.
Does it have a typical PCV Valve?
jimtreber
01-17-13, 03:30 AM
Why would the isolator affect the breather? The isolator only raises the IM, not the filler cap on the cam cover. Am I missing something here?
HurstGN
01-17-13, 06:50 PM
It isn't a little oil, it's puddles of oil in the plenum. And the buildup on the vales is unbelievable. It builds up so much it will restrict the airflow to the motor. DI needs the catch can, no doubt about it.
jbelot
01-21-13, 01:36 PM
You are correct but when you put the isolator on the fit of the engine cover is compromised just enough and rubs the hood isolator a little bit. Add that to the breather hitting the hood and you need to compress it in order to not bend our dent your hood it all gets very sloppy and very amateur looking.
Just a quick note. I now have 3 catch cans installed on 3 different cars and 2 isolators from RX. They may have a long lead time but sometimes good things are worth waiting for. They always get you your product and the quality is amazing. Well worth the wait!
tinman
01-21-13, 01:38 PM
There are others that have excellent quality and had my interest. I bought the RX because it, too, was of good quality, has good reviews on this website and the Camaro website, and they sponsor our website.
SC2150
01-21-13, 01:56 PM
Pitchblack....we answer every email and return all calls, but give me the name and contact (address & phone) and we can look it up and give tracking. Emails and PM's run 200-300 a day but we go through all.
Phone is: 941-721-1826
Email is: RXProducts@aol.com
Phones are generally busy so leave a voice mail with all your info and we respond w/in 24 hours usually.
All we know most memebers by on the forums is the user name so we usually dont know who the order name is under, but should be no one over 3 week old orders. Oldest we can see are 2.5-3 weeks.
:thumbsup:
MochaSteelCoupe12
01-25-13, 08:36 AM
:thumbsup:
I just went to to RXProducts website looking for a catch can for my 2012 CTS Coupe and your site only offers parts up to 2011 cars. Are you going to offer the can for 2012 cars?
I went to the RXProducts website to order a catch can for my 2012 cts coupe but the website only offers product for car up to 2011. Are they going to make a can for the 2012.
