: 2003 Cadillac Escolade EXT - Tonneay Cover Leaks
dgormley
11-17-12, 07:12 PM
I have a 2003 cadillac escolade EXT and the tonneau cover started to leak over all my items below. Is there a way to readjust the panels so they do not leak. The rubber looks ok with no wear or rips. They leak at the seams between the panels in the middle. Anyone know what is the problem. Thanks!
the cadillac man
11-17-12, 07:57 PM
Have you checked the seals between the panels were they contact each other?
They may be worn and need replacing.
zapconj
11-19-12, 02:33 PM
I had a similar problem on one panel on my 04. Check to make sure the Rubber seals are seated properly on the panels. I had one panel where the rubber was not seated properly. Water all over the bed.
You may also be able to order a new seal kit from GM. Check ebay or some of the other vendors on this site.
