: Need part number for platinum headlamp jumper harness
cadmanchris
11-15-12, 05:03 PM
Hi all. Just acquired a set of platinum headlights and need the part number for the jumper harnesses. Thanks.
baggedlvintegra
11-15-12, 05:19 PM
Good luck with the conversion if yours is indeed an 07 ESV. After all the reading I have done (thanks to WaterKing) the 07s are not a direct plug and play. You have to re-pin the harnesses, do a Flash and I believe run some other wiring for it to function properly...I had a deal lined up on some platinum headlights CHEAP but I didn't want the hassle to make them work on my 07
cadmanchris
11-16-12, 12:03 AM
Thanks for the heads up. I guess that I'm gonna have to research a bit.
cadmanchris
11-22-12, 02:08 PM
Ok, after doing some schematic comparisons between the '12 Platinum headlights and my '07 truck, the main difference is in the DRL circuit. The platinum headlamps uses a DRL resistor whereas the 07 does not. The only way to get the resistor is to get the forward lamp harness. So I ordered the harness. It will be in next week.
baggedlvintegra
11-22-12, 02:16 PM
Please keep me posted on whether or not you can make this plug and play on an 07 with an additional harness. I still have the deal available on the headlights and will for sure go pick them up if you get this worked out!
cadmanchris
11-22-12, 02:33 PM
The harness will be in next week, according to my parts guy. I will check the harness when I get it and will let you know the results.
What's the trick to upload pics from my iPhone? It keeps saying the file is too big.
cadmanchris
11-28-12, 08:55 PM
Bagged, I tried to send you a p/m but your inbox is full. Got the harness today.
baggedlvintegra
11-28-12, 08:58 PM
just cleaned it out, sorry..do we have a verdict yet?
soulsea
11-28-12, 09:04 PM
So how hard is it to make these plug and play in an 11? :)
Do I need this harness?
cadmanchris
11-28-12, 09:07 PM
Will let you guys know when I attempt it on Saturday hopefully.
baggedlvintegra
11-28-12, 09:09 PM
Should be straight plug and play for you serge
soulsea
11-28-12, 09:11 PM
Mmm, interesting ... this could get expensive. :)
Are we sure or is there a way to check?
cadmanchris
11-28-12, 09:19 PM
Can't really say for an 11, but after comparing the wiring schematics, it should all work out. I have the headlights and harness. Just have to make the time to do the swap.
baggedlvintegra
11-28-12, 09:21 PM
From what I gather in this thread
http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum-2007/195774-platinum-headlights-not-running-during-day.html
It is only the 07/08 Models that have the issue with the harness / pins / relay / wiring not working without modification
soulsea
11-28-12, 09:25 PM
K thanks ... it looks like you might be correct.
I wonder if I'd still need a BCM reflash or if I just plug them in and go.
baggedlvintegra
11-28-12, 09:32 PM
I think once Chris does his we should know. He is going to be replacing the whole harness and if everything works once he's done it should let us know if a BCM reflash is necessary
soulsea
11-28-12, 09:36 PM
http://i116.photobucket.com/albums/o2/phototrekker74/gifs/cartman.gif
cadmanchris
11-28-12, 10:51 PM
I don't think that any rue flashing of the BCM is needed.
I went through WaterKing's post from 2010. Not too sure if he used a Platinum harness, but the DRL relay is already taped into the new harness that I ordered.
baggedlvintegra
11-28-12, 11:27 PM
I agree with you Chris, I believe what you have ought to get everything squared away. *fingers crossed*
