: STS-V brembo front set up swap
1BadCadSTS
11-15-12, 02:30 PM
So as most of you know the V series brembo calipers bolt right on to our cars the issue is that the rotors on the V are a 6 lug set up while the non v is a V
Also as most know there is not a simple way to convert to the 6 lug set up cheaply
I had a custom shop machine me some rotors and now the time as come they are toast and Im not about to spend another 500 on custom rotors.
I think I have found a solution for a rotor WHICH will bolt right on and with a spacer work on all 05-07 1SG cars, 08+ use a different wheel with less spacing so I do not think those wheels will work.
I have ordered a set of rotors for thiis car and from there will update if it works. Dont want to get anyone too excited but Im 95% positive this will be a bolt on solution for anyone interested.
Ludacrisvp
11-15-12, 03:13 PM
cool, on the back of the 18" rim used in 08 it says offset is +51mm not sure if that is the clearance you are talking about.
1BadCadSTS
11-15-12, 03:49 PM
Those won't even come close then.
05-07 are 42 mm offset an will only clear with small spacer due to the spokes.
V series have 42mm offset.
1BadCadSTS
11-19-12, 05:41 PM
Got the rotors today
they fit PERFECTLY!
I have an old hub assembly I kept for this very reason along with my old OE set of rotors
now just to wait to get my car back from the dealer to bolt everything up
aliskerov
11-19-12, 10:00 PM
Would love to hear the result. Keep us posted!
scott9001
11-20-12, 04:31 PM
so did you get a rotor made? get some pictures to this thread
1BadCadSTS
11-20-12, 05:41 PM
Originally I did. I now found a rotor from any part store which should work. Love to post pics but my cars still at the dealer!
burkewm
11-22-12, 10:03 AM
Anyway you could post some more details about this? Where did you find/buy your brembo calipers, what rotors did you get? Also I have an '09... might have to do some more research.
EChas3
11-22-12, 04:22 PM
Let's see some facts or it's just fiction.
Anybody can say anything.
Ludacrisvp
11-22-12, 04:52 PM
Wouldn't the 51mm offset indicate that it has more clearance than the 42mm offset? I'm no rim offset expert so I ask.
1BadCadSTS
11-22-12, 07:46 PM
Want a picture of the CTS loaner? Mines in the shop still haha.
Trying to find out is CTS brembos are the same as STS to do a full parts list needed for conversion. Relax guys I will share once I'm sure everything is complete.
Platinum06
11-27-12, 09:54 PM
cool!
scott9001
11-29-12, 08:18 PM
jeeze your car must be getting a major overhaul.... you ever see what pimp my ride can do in 7 days lol joking
1BadCadSTS
11-29-12, 09:00 PM
HAHAHHAH
Yea I just got it back yesterday they had to special order the rad (took time due to holiday) as well as all four cam actuators 4 brand new dws contis and inspection/emissions.
Anywho dove into it tonight and it looks like it wont work. The "sourced" rotor is MUCH thinner in the hub, while everything on the brake side fits and mounts perfectly the CALIPER will not clear the wheel due to this difference and I will need a 1 inch spacer to clear now.
Since our wheels are HUB centric using a simple spacer was OK with the custom made one as it still maintained enough to still provide some hub on rim contact, this new set up will not. I must find someone to produce a 1 inch wheel spacer to that is HUB centric.
Thus far this seems like the option
http://www.ebay.com/itm/HUBCENTRIC-PNP-WHEEL-SPACERS-25MM-5X115-BUICK-STS-05-08-/150821724397?pt=Motors_Car_Truck_Parts_Accessories&hash=item231dace0ed&vxp=mtr
I have emailed the seller to ensure they will work on a STS hub using a stock wheel before purchasing.
Will continue to update
scott9001
12-02-12, 01:54 PM
did the calipers fit behind you stock wheels actually? and okay im verry interested in this if there is anything you need to know let me know and i can look into it do you have the specs for the rotors you need post them or pm me them and i will look into it also
1BadCadSTS
12-02-12, 03:34 PM
Read up. With oe spec rotors it did. The other rotor I'm using has less meat on the hat and thus will not fit without a spacer.
Ludacrisvp
01-21-13, 10:46 PM
How are the brakes these days?
1BadCadSTS
01-22-13, 09:09 AM
Haven't touched it yet. Still need to find a spacer i trust. Only ones I can find are on eBay and I'm not sure I trust them. Search 25 mm hub centric 5x115 spacer and you'll see.
scott9001
01-22-13, 10:02 PM
where did you find the hat spec did you find any online? i am looking because the 2008 chrysler 300 srt8 has a 5x115 bolt pattern and a 14 inch rotor! just need to find the hat size and to be completley honest with you im pretty sure the regular 300 and out sts share the same brake calipers on some modles but not to sure about that
1BadCadSTS
01-23-13, 02:37 AM
Center hub bore on 300c is far too big and unsafe.
Once I find a quality spacer I trust ill share. I am not going to be responsible for some idiot slapping parts on their car which can get someone killed. Brakes are the last thing you want to play with.
Ludacrisvp
01-24-13, 10:22 PM
I'd be a little overly cautious before I'd use rotors made for another automotive line like Chrysler parts on a GM car. Granted I do have 02 camaro SS dual piston calipers on my 01 monte SS but all that was needed there was tap out the camaro caliper bracket to take the 14mm bolt of the monte instead of the 12mm bolt of the camaro. Anyone know someone who can make them (spacers) custom that doesn't cost an arm?
1BadCadSTS
01-26-13, 07:46 AM
The spacers for the rim are cheap. I don't trust them. Eibach doesn't make a set for our car no company I've herd of does. Only these eBay ones which don't sit well with me.
scott9001
03-07-13, 10:27 PM
i read you finished the swap lets see man!
Ludacrisvp
03-25-13, 07:34 PM
I wonder if they can make the right spacers for us?
http://www.motorcitybolton.com/wheel-spacer-plates/5-lug-wheel-spacer-plates.html
What car is/was that car that you found that had the right rotors or were those unreliably thin?
1BadCadSTS
03-26-13, 12:12 PM
2005 Shelby gt500 mustang.
Ludacrisvp
03-26-13, 12:38 PM
So if the rotors from that car work, what are the chances of there being a hub centric spacer that is made for that car that would work for ours?
For the 08+ we would need a 9mm spacer in addition to the GT500 rotors?
1BadCadSTS
03-26-13, 04:14 PM
The lugs are not the same. They are fine for a rotor not for lugs.
Mustang 5x114.3
Sts 5x115
Ludacrisvp
03-26-13, 07:33 PM
Boo. Why does everyone else use 114.3mm? 115 just seems like it would make more sense.
EChas3
03-26-13, 08:41 PM
To annoy somebody who calls themselves Luda....
Ludacrisvp
03-26-13, 08:48 PM
Lol. It certainly limits options.
1BadCadSTS
04-06-13, 06:22 PM
See
http://i50.tinypic.com/309sbqt.jpg
scott9001
04-07-13, 05:50 PM
did the factory flex line bolt right up to the caliper or did u use the one from the V?
1BadCadSTS
04-07-13, 07:01 PM
Just bolted on for mock up. Still need to fix the wheel clearance issue but this was to show the gt-500 rotor works flawless.
Ludacrisvp
08-25-13, 06:57 PM
So I drove through the Cadillac dealer today.
Saw a used 2013 XTS4 Platinum w/ 4,300 miles on it in the back of the building. It had some odd stickers on it from GM that made it look to me like it may have been a GM buyback car / lemon-law return on it.
I was surprised to see that it had brembo brakes on the front w/ 5 lug rims too.
This car might give us some additional options for rotors and calipers for the STS and perhaps wheels too.
Not sure on the fine detailed specs of the entire setup but it certainly caught my eye.
Side note, it had its fuel door ripped off of the car too.
This made me notice that the XTS doesn't have a fuel cap, you just put the nozzle into the hole and a little flap opens up for the gas to flow in.
1BadCadSTS
08-25-13, 08:00 PM
Xts is 5x120. Ats has brembos and 5x115.
Calipers will not work from either of them nor will rotors.
Sts v calipers gt500 rotors and ats wheels = win
Or cts-v replicas from oe wheels.
Ludacrisvp
08-25-13, 08:19 PM
lol you certainly have checked all of the options out already...
btlegacy
09-04-13, 01:42 PM
Looking at the specs for the GT500 Rotors I see their hub reg is 71.00mm while the STS is 70.87mm which means that it is insignificant as manufacturing tolerances can account for that 0.13mm difference which is equivalent to 1/200th of an inch. As far as the rotor hat spacing, does the rotor line up into the middle of the caliper when placed on the hub?
1BadCadSTS
09-04-13, 04:04 PM
Pretty sure I posted a pic that shows it fits just fine
btlegacy
09-04-13, 04:05 PM
I see your pic above and it looked great, I just wanted to make sure there wasn't anything else required before I ordered the rotors
1BadCadSTS
09-04-13, 04:32 PM
2 washers to space the the caliper and 40mm offset wheels or a good spacer for stocks.
sub613
09-04-13, 08:22 PM
1BadCadSTS: What stock brakes did you car have before the swap ? JE-5 ?
AND: Are those 4 piston calipers ?
They don't say Brembos, and are not RED, so it is fooling me, visually.
Thanks :cool2::cool::cool:
Guy.Seminerio
09-04-13, 08:27 PM
For the record the v brake calipers are silver with black v logo and are brembo 4 pistons
1BadCadSTS
05-07-14, 03:35 PM
Just a small update... Got spacers... Should be here Friday....
STS JE5 Centric rotor...
http://www.rockauto.com/getimage/getimage.php?imagekey=2034366&imageurl=http%3A//www.rockauto.com/info/Centric/121.62088_DRA.jpg
ATS J55 Centric rotor...
http://www.rockauto.com/getimage/getimage.php?imagekey=4557921&imageurl=http%3A//www.rockauto.com/info/Centric/125.62138_DRA.jpg
hummmmm.... makes me wonder if in fact ATS caliper will work as a direct bolt on to our cars with ATS rotors....
Our STS uses a 12MM caliper bolt while the ATS uses a 14MM
http://www.mcmaster.com/#catalog/120/1150/=rv5kcg with PN# 6679K16 should fix that...
ATS Caliper is about 1/4" skinner than the V1 also the rotor is taller meaning it will sit deeper in the wheel, meaning smaller offset wheel can be used perhaps a stock one also ATS Brembos clear 17"s....
Just stirring the pot....
Ludacrisvp
05-07-14, 05:18 PM
Maybe if I didn't just complete a full set of brakes last fall I'd look into doing this...
gazayute123
06-24-14, 11:27 PM
hey man can you please tell me how the cts-v calipers with the mustang gt500 rotors work out did it hold up and what rotors did you use for the rear im trying to get some feed back please and thank you
1BadCadSTS
06-25-14, 01:20 PM
I have yet to actually install them. I finally finished the Heads Up Display retrofit and then bought a Grand Cherokee which has taken a significant amount of my time along with finally finishing up a few things on the Camaro.
I HOPE to install them at some point this month since I have all the parts and invested all the money in it, its just a matter of installing everything. My greatest fear is the spacers will stick my wheels too far out and look stupid but we shall see...
Ludacrisvp
06-25-14, 03:08 PM
So put the spacers on and see how it looks before you do the rest of the work.
btlegacy
09-29-14, 10:50 AM
That is very interesting and I was looking into that as well. Especially since the ATS brembos are popping up on Amazon now:
http://www.amazon.com/ACDelco-172-2586-Original-Equipment-Assembly/dp/B00B4KP8E8/ref=sr_1_1?ie=UTF8&qid=1412000338&sr=8-1&keywords=172-2586
How thick were the washers that you used? I am waiting on my calipers to come in and was thinking of ordering a thicker washer to use instead of 2 thinner ones.
See
Ludacrisvp
09-29-14, 11:13 AM
Looking at those pics again and that must be the STS rear rotor and ATS front rotor. Based on the design of the STS photo it's clearly made for the drum based emergency brake.
btlegacy
10-03-14, 12:06 PM
I checked out the ATS setup and put them side by side. You would have to use the ATS rotor as it is slightly smaller and slightly thinner. The only thing that may be an obstacle is that the hat seems to be deeper so that may bring it on closer to the spindle.
http://s30.postimg.org/lrpmo4o9t/STSrotor.jpg
targetSTS
10-04-14, 03:31 AM
I also checked it. looks like calipes+rotors and pads from ats should fit. And this will be better setup for me, cause i don't want to use any spacers with my oem wheels.
Who will be the first to buy and check?:)
1BadCadSTS
10-04-14, 09:42 AM
The major obsticle is confirming if the caliper ears on the ATS and STS are the same.
Pictures are vague at best. Both specs I posted were for front rotors.
btlegacy
10-04-14, 10:39 PM
Found an ATS Caliper listed on ebay with measurements
http://img.auctiva.com/imgdata/1/2/7/4/7/0/7/webimg/725127822_o.jpg?nc=34
I have also been researching rotors to go along with the STS-V Caliper and I have found one that is almost perfect. The only problem is that it is for the Australian Ford Falcon and I have not found a cheap way to get it in the US. Specs are below:
http://s4.postimg.org/56w4y2tot/STS_Vrotor.jpg
1BadCadSTS
10-05-14, 09:58 AM
Wrong GT500 rotors work just fine with V calipers. I posted mock ups. Only issue is wheel clearance.
Also link for the pics? Could be an xts caliper. Looks the same.
btlegacy
10-05-14, 10:25 AM
I tested the GT500 rotors and saw that they work. I was looking for something with a similar hat height so I could mount the calipers directly to the spindle and not space them forward as I only need a few mm to clear my wheels. Here is the auction that the image led me to: http://www.ebay.com/itm/2013-Cadillac-ATS-XTS-Front-Left-Right-Brembo-Calipers-New-With-Scratches-/400629462707?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d476076b3&vxp=mtr
1BadCadSTS
10-05-14, 10:16 PM
Very suspect.
ATS and xts calipers I am 90% sure are NOT the same.
Ludacrisvp
10-05-14, 10:25 PM
Is the ATS brembo caliper even any better than our current calipers? It's hard to tell in those photos but they just look like 2 piston calipers to me... Maybe they are 4 but they didn't show a decent angle of both sides of the inside of the calipers.
btlegacy
10-06-14, 10:12 AM
They have 4 pistons and I agree that the calipers look different. This is the part number I Found for the XTS caliper
http://www.amazon.com/ACDelco-172-2592-Original-Equipment-Caliper/dp/B00B4KP9R4#
1BadCadSTS
10-06-14, 01:43 PM
They have 4 pistons and I agree that the calipers look different. This is the part number I Found for the XTS caliper http://www.amazon.com/ACDelco-172-2592-Original-Equipment-Caliper/dp/B00B4KP9R4#
As I thought. I've had both as loaners and seen them. The ATS caliper is much smaller and probably has a shorter ear length so smaller rotor and why they can be had on 17" wheels. The smallest XTS wheel option is 19 though it looks like an 18" MAY clear.
btlegacy
10-06-14, 03:22 PM
Yep, it appears that the XTS shares the brake setup with the Buick Regal and runs a 345mm (13.6in) front rotor while the ATS runs a 321mm (12.6in) front rotor and the STS-V runs a 355mm (14in) rotor.
This confirm that there is no way the calipers can be the same as the ear length has to be different. The spacing may work to bolt up but you would have to match a rotor to the listed size. The XTS caliper may be an option if it bolts up and if we can find a good 345mm rotor to fit.
The XTS (30mm) also runs a thinner rotor than the STS-V (32mm)
http://www.rockauto.com/getimage/getimage.php?imagekey=4558413&imageurl=http%3A//www.rockauto.com/info/Centric/120.62140_DRA.jpg
Ludacrisvp
10-06-14, 05:36 PM
someone go raid the parts store with ATS and XTS calipers and a bunch of random rotors and our stock 18"s and see what fits
btlegacy
10-07-14, 10:08 AM
I have been keeping a list of the different sizes of front rotors for STS, CTS, ATS, XTS, V, and Camaro. Figured I would add that to the thread as well
http://s21.postimg.org/9bqxqc2sn/Rotors.jpg
In addition here is the list of rotors I have been compiling from the web and from 1BadCadSTS's suggestion as possibilities to work on 5-lug cars with the STS-V caliper. Highlighted boxes are for items that would need to be modified.
http://s30.postimg.org/gqq1rpgn5/rotors2.jpg
cdezey
10-07-14, 01:10 PM
Have you considered Ebay Australia.
btlegacy
10-07-14, 03:03 PM
I checked it out. At first look the best I saw was $290 for a set of rotors plus $140 shipping to the US.
btlegacy
10-08-14, 04:21 PM
I picked up a Camaro SS rotor as its a perfect match in size and height but does not have all the holes of the STS-V rotor. I am going to get a machine shop to bore it out and redrill for the 5x115 lug pattern. I have done some research and feel completely safe in re-drilling them. This is from a Honda forum but applies to this project just as well. http://honda-tech.com/suspension-brakes-54/safety-redrilled-brake-rotors-2374111/ The rotor I picked up is the one below:
http://ecx.images-amazon.com/images/I/31gmagcqKeL.jpg
Once re-drilled it will look similar to the following:
http://i1163.photobucket.com/albums/q560/trexreilley/IMG_0416_zps5762217f.jpg
Ludacrisvp
10-08-14, 06:49 PM
But once it fits on the hub will the caliper still line up with the rotor and will you be able to clear the caliper with the rim?
Also are you using STS-V Brembos or ATS or XTS or Camaro SS brembos?
btlegacy
10-09-14, 08:38 AM
Based on my calculations it should all line up as there is only 0.3mm difference in the hat height. Once it is bored and drilled I will test it and see. This should help me to clear my rim better as it will bring the caliper about 3.7mm closer to the spindle. I am using a standard STS-V Brembo caliper. I first looked at re-drilling the STS-V rotor but with all of the small holes on the face of the hat I believe that is not possible so I am leaning towards this one. I should have the rotor in today to take more measurements and will drop it at the machine shop tomorrow.
ShDmitry
10-11-14, 12:05 PM
Re-drilled STS-V rotor does not look very nice but works well.254529254537254545
Ludacrisvp
10-11-14, 02:29 PM
Spacer details? Which oem rims are you using?
1BadCadSTS
10-12-14, 10:21 AM
rim clearance is the only issue I'm facing on my swap.
ShDmitry
10-12-14, 11:32 AM
Spacer GT-500 1" with shim inside, 18x8 oem rims, front and rear STS-V brembo swap:
254953254961254969254977254985254993:yup:
On the rear you need also to swap brake hoses.
Ludacrisvp
10-12-14, 11:55 AM
Did you make the shim or ?
ShDmitry
10-12-14, 12:33 PM
Yes. To reduce the diameter from 71mm (GT-500) to 70.6mm (STS).
1BadCadSTS
10-12-14, 04:35 PM
Same issue. I have proper spacers though. I just don't trust them.
What rotor did you use for the rear?
ShDmitry
10-13-14, 05:05 PM
STS Factory Brembo J56 Rotors R1 Concepts Eline Series (http://www.ebay.com/itm/390485442906?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT) and Hubcentric Wheel Spacers. (http://www.ebay.com/itm/1-0-5x4-5-to-5x4-5-Hubcentric-Wheel-Spacers-1-2-Studs-1-inch-5x114-3-/281342115067?pt=Motors_Car_Truck_Parts_Accessories&hash=item41814bfcfb)
18000 miles without any problems.
1BadCadSTS
10-13-14, 07:51 PM
So you ended up using V rotors and redrilling them.
Ludacrisvp
10-18-14, 10:16 PM
So I still cannot understand why it is that the STS wheels used in 08 don't work...
Specifically this rim type:
http://i.ebayimg.com/00/s/MTYwMFgxNTk5/z/Fn0AAOSwR0JUMs0b/$_57.JPG
Here are the specs of the rim used on the 08+ STS:
18" x 8.0" +51mm
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/b14AAOxydlFS4nel/$_57.JPG
Here are the specs of the front 18" rim from the STS-V:
18" x 8.5" +51mm
http://i.imgur.com/CcrZjSB.jpg
Here is a side by side comparison using the +42mm spec you provided in the 3rd post (rather than the +51mm that is actually stamped in the wheel):
So if I read this correctly the STS 1SG wheel actually has 2mm more backspacing and therefore more clearance than the STS-V does between wheel and caliper.
http://i.imgur.com/T9rQEKO.png
Here is a side by side comparison of the wheel specs using what is actually on the rim:
So if I read this correctly then you only need 7mm of additional spacing to clear the caliper.
http://i.imgur.com/Tayzx04.png
ShDmitry
10-19-14, 12:23 PM
Hubcentric wheel spacers available only from 10mm, so you will also need longer studs.
I have rims from older model, 2006 or 2007.
sub613
10-22-14, 06:04 PM
TO SUM IT UP ! Stock 18" and definitely 17" rims will NOT work.
So what will work ? Can someone Please sum up the whole conversion .
Thanks
Happy Motoring !:cool2::salute::patriot:
1BadCadSTS
01-29-15, 06:05 PM
Update
I got an ATS "test" car. The ats 18" will NOT clear v1 brembos. Just going to run the spacers I got and complete the swap this weekend.
cdezey
06-01-15, 11:29 PM
Hey guys does anyone think this factory wheel, could useful for the swap.
Sorry tried to upload a photo (CTS sport package 4597) looks like speedline sts-v wheel but our bolt pattern.
Boat
07-10-15, 01:55 PM
Update
Any updates? I found some CTS V1 calipers for pretty cheap and am considering the swap if it's worth the effort.
cdezey
07-12-15, 04:10 PM
Yeah I would like that information as well,I installed the rear calipers and needed spacers after install had to walk to advance auto.
targetSTS
08-11-15, 08:32 AM
well, somebody must to be the first :)
just a small report about my front brembo swap to ATS 4-piston brembo calipers.
first, why ats brembo/not sts-v:
1) i didn't want to deal with 6-lug setup for sts-v
2) ats brembo calipers looks better in grey color (for my grey car) with brembo and cadillac scripts.
3) ats brembo rotors and pads much cheaper and always in stock (for my location), also ats brembo calipers cost less new.
4) stock 18" sts wheels can be used (i believe 17" as well)
- so I got 2 calipers from ATS:
ATS caliper (https://drive.google.com/file/d/0B9S1rdIXNwvOeUE4S0VsOHJtQkk/view?usp=sharing)
the first problem - ATS calipers has mounting holes for M14x2 bolts, STS calipers - for M12x1,75.
I gave both calipers to my local turner. He extrude threaded sleeve and made new with thread needed for STS bolts.
pic (https://drive.google.com/file/d/0B9S1rdIXNwvONVRvZG9BNWYzLU0/view?usp=sharing)
now calipers can be installed bolt on.
- got front ATS brembo rotors and pads. Rotors has 5x115 bolt cycle pattern and hub reg -70,75mm - same as STS. 321mm diameter is also the same as JE5 STS
the only different parameter is rotor height 61mm for ATS and 51mm for STS.
So spacer between hub and rotor is needed to fill 10mm gap and place rotor at the center of the caliper.
My local turner made it for me from Aluminium. I don't have pics of the spacers, but looks the same:
reference only picture (http://www.pelicanparts.com/catalog/images/Turner/wheels_bmw_wheel_spacer_5x120mm_spacer_15mm_1.jpg)
also hubs was cut for 8mm to place spacers correctly and leave same 10mm space for wheel as stock.
- all 10 STS hub studs M12X1.5X40 was replaced with longer M12X1.5X50, which i found at local shop from buick\gmc\pontiac
pics of caliper and rotor (without correct spacer, you can see there is no gap on hub to place a wheel) (https://drive.google.com/file/d/0B9S1rdIXNwvOMldmWGhpREsxbW8/view?usp=sharing)
with wheel installed (i know 08+ wheel not the best to show up calipers :))) (https://drive.google.com/file/d/0B9S1rdIXNwvOUzFEZFh2dkI4bzA/view?usp=sharing)
brake hoses remained stock but was bent a little to set in ats caliper.
parts needed:
1) heavy duty J55 ATS front calipers:
22760030 -LEFT
22760031 -RIGHT
about 100$ each at amazon
note: due to different caliper position on ATS (at back) and STS (at front). LEFT ATS cailiper goes to RIGHT on STS, RIGHT ATS caliper - to LEFT on STS.
2) 4 new caliper threaded sleeves for M12x1,75 bolts
3) 2pcs FRONT ATS BREMBO ROTORS - 13585030 (ACDelco #177-1137) - about 100$ each
4) front ATS brembo brake pads 22866931 PAD KIT, FRT DISC BRK (INCLS 2, 4) (ACDelco #171-1102)
or directly from brembo BREMBO P59079
or completely the same (difference only in number of wearing sensors) from SUBARU IMPREZA STI or MITSU LANCER EVO- BREMBO P54039
or EBC Brakes DP31210C Brake Pads - Redstuff
or EBC Brakes DP21210 Brake Pads - Greenstuff
5) 2pcs 10mm spacers between hub and rotor
6) 10pcs hub studs M12X1.5X50
7) pin kit GM 22813180 - 2pcs
:cheers:
cdezey
08-11-15, 12:40 PM
You sir are the MAN!! if had not already invested I would have went that route.
I had to buy (kv5 sport wheels) from tire rack to complete the rear, still have not completed the front.
eddyg
01-27-16, 01:52 AM
Success at last! Front 14" Brembo rotors, with 4 piston Brembo STS V calipers and STS-V pads mounted and working great on a 2010 STS-4 with 18" OEM wheels. Thanks to all that have contributed to this thread, you helped my project very much with good ideas and theories.
Components: 355mm Delco rotors from a 2010 Camaro RS; Calipers, Pads and Pins/Clips from the 2009 STS-V, 2mm Wheel spacers.
The Camaro rotors have the correct hat height, thickness and most other dimensions for this application. Center bore was enlarged to 2.785" (70.75mm), and the lug holes were modified to fit the 5 X 115mm lug spec. The single holes in the rotors for the hold down stove bolts were re-drilled in the correct place.
The 14" rotor gives substantial stopping power due to the higher leverage ratio vs stock. The rotor goes right on the stock hub. The 2mm wheel spacers give the caliper to wheel a resulting clearance of 3.7mm (Brembo recommends 3mm minimum). The whole set up has about 15mm clearance for height on the OEM 18" wheels, so no worries here!
As stated in the first post on this thread: The calipers bolt right on, however it is necessary to use the STS-V spec versions. They have the correct leading/trailing piston set up and are designed to mount in front of the axle. The OEM 12mm bolts for the stock PBR calipers work fine with the STS-V spec 4 Pot Brembos. No shims between the calipers and the front suspension member are used.
With the Camaro rotor no shimming between the hub and rotor is necessary for this set up. The stock wheel studs are more than long enough, as this set up only needs the 2mm spacer to get the required caliper to wheel clearance.
Of all the rotors that have specs that are close: The Delco rotors for the 2010 Camaro RS are the only ones that correctly place the rotor squarely in the center of the caliper - and do it without shims and/or machining. All others are lots of work and parts.
The brake hoses bolt right up with no modification. Factory spec brake bleeding was accomplished with no issues. The finished product looks good works great! Plus, if you have a professional doing your install they will see the simplicity and OEM engineering of this set up and will not think twice about proceeding.
Everything is bolt on, serviceability is excellent and the whole set up is sanitary & OEM looking. Parts are minimized, machine work is kept reasonable (affordable and available) and the parts needed are available for reasonable prices, with retailers such as Amazon and other Delco part suppliers. There are no real secrets here!
Again, thanks to everyone that contributed on this thread! You gave me the facts and ideas that resulted in what I believe to be as close as we can get to the way GM did it on the STS-V, without resorting to 6 lug hubs and wheels. I avoided the machine work, parts, costs and complexities and ended up with the sort of projects that is in-expensive (relative to a Big Brake Kit) and brutally effective.
Now, how do you put a turbo on this thing?
1BadCadSTS
01-27-16, 08:20 AM
Even with the Camaro rotor I'm wondering how you only used a 2mm spacer. 08+ wheels must have more clearance though ivthought they were the same specs.
eddyg
01-27-16, 01:54 PM
The specs on the 08+ wheel are likely different (Offset?). I was pleased to see the fit. As they are 5 on 115mm the newer spec wheels should bolt on to all STS 2005 to 2007 (non V spec).
1BadCadSTS
01-27-16, 02:23 PM
Both show 51mm offset
Ludacrisvp
01-27-16, 08:54 PM
There are more than 1 set of 18" wheels for 08+
eddyg
01-28-16, 01:49 AM
Here is one more piece of the puzzle: You need about 1.05" of clearance from the stock PBR caliper to the wheel spoke to clear the STS-V Brembo caliper. My wheels were the stock 18" for a 2010, might have been part of an option package as I think 17" were common. The front tire size is 235/50/18, rear is 255/45/18. I think they are an 8" or 8.5" wheel width.
eddyg
01-31-16, 09:19 PM
The Camaro rotor hat is slightly thicker and may have helped the clearance a little.
eddyg
02-07-16, 04:11 PM
The other reason to go with the Camaro AC Delco rotor is weight - it is the lowest weight of all the possibilities for this application using a 14" (355mm) rotor. The fact Brembo makes them does not hurt anything either!
cdezey
02-08-16, 09:46 AM
Can u post a picture front and back' close up of the back please.
eddyg
02-08-16, 10:07 PM
http://www.amazon.com/ACDelco-177-1050-Original-Equipment-Front/dp/B0049HQ2M0/ref=sr_1_13?ie=UTF8&qid=1454987197&sr=8-13&keywords=2010+camaro+brake+disc
cdezey
02-09-16, 06:31 AM
I meant the wheels thanks in advance.
eddyg
02-15-16, 05:33 AM
Looks like this one:
http://www.carid.com/2010-cadillac-sts-factory-wheels/replace-factory-alloy-wheel-61333050.html
Cadillac STS 2010, 18" Cadillac STS 2010, 18" x 8". Bolt Pattern: 5 x 115mm.14 Spokes Bright Polished Factory Alloy Wheel
and: http://www.ebay.com/itm/Set-of-4-Chrome-18-Cadillac-STS-OEM-Factory-Wheels-Rims-CTS-DTS-4631-/291671374930?hash=item43e8f7fc52:g:oWsAAOSwstxU9eb E&vxp=mtr
eddyg
02-22-16, 06:48 PM
OEM take off wheels are cheap used! After using this Brembo set up for a month I must say I should have done this conversion sooner. The system feels very balanced with the 12.6 rotors in the rear and the 14's on the front. Wheel clearance is an easy to fix area. I am very pleased!
BlownGP
03-03-16, 10:14 AM
So does anyone think the XTS turbo Brembo's mount the same as the Gen 1 CTS V brembo's??
I see that the Regal GS calipers are the same as the Gen 1 CTS V's. Rock auto claims the Regal GS use's the same front rotors as the XTS when you look under XTS parts. But if you look at brake rotors under Regal parts they don't list them fitting the XTS. Just the G8, SS etc....
eddyg
03-03-16, 11:35 AM
They are different diameter (10mm less) and the hat height is such you may find the rotor is not centered in the caliper.
BlownGP
03-03-16, 12:38 PM
I was thinking of using a 14" GT500 rotors. Like you would use with the G8 GXP and SS brembo's. You think that would work?
sub613
03-03-16, 06:34 PM
Guys, With SO many aftermarket parts for everything on earth,
Why do we not have an after-market 4 piston that fits our cars ?
I would seriously consider it, but NOT with the Brembo's price !
Why would Cadillac, a luxury car, with a luxury price, put out
a car with Crappy Brakes, JL9, for instance.
Happy Motoring :):stirpot::yup:
eddyg
03-04-16, 03:26 PM
Q: "I was thinking of using a 14" GT500 rotors. Like you would use with the G8 GXP and SS brembo's. You think that would work?"
A: The hat height on the GT500 rotor puts the disc face outside of the alignment window of the Brembo caliper in the STS application, unless you do some spacers and/or adapters. I did not desire to use any unnecessary parts. The GT 500 rotor also weighs more.
Q: "Why do we not have an after-market 4 piston that fits our cars ?"
A: The Brembo is a superior product and for $250 (or less) is a relatively good deal.
Q: "Why would Cadillac put out a car with Crappy Brakes - JL9, for instance."
A: If you cannot find a logical answer: The reason is usually money.
BTW as bad as the JL9 and JE5 may be: My previous Audi A8 had the same crummy brakes as an A4 and they caught on fire under severe use. Most drivers will find the stock brakes OK, if they are not pushed to hard.
The Brembo product, purchased through AC Delco, is an incredible value IMHO. When thrown a bone, bark like a dog, and take it!
EChas3
03-04-16, 09:04 PM
For GM to bring an STS to market with an MSRP near $40G, a lot of 'first choices' were downgraded.
kzx03p
06-08-16, 03:23 PM
to: TargetSTS - I'm doing the same J55 Brembo ATS caliper swap on my 06 STS JE5...the jounce hose situation is what confuses me the most. It's because there's no longer any complete vehicle math data to look at in Unigraphics for the Sigma architecture. Do you have some pictures of your jounce hose setup? I ordered a set of ATS hoses #23182553,4 and it appears these may work well based on my limited CAD studies.
Also, regarding the M14 fasteners for the caliper, I'm just going to bore out my knuckle to make the bolts fit (using the M14 bolts from the STS-V #11570092) instead of re-bushing the calipers. I'm also going to use the stock 2009 JE5 rotors, because they are almost a perfect fit...just may need to machine 1 to 2 mm off the outer edge of the pads since the rotors (315mm dia) are a tad small for them compared to the ATS (321mm dia), but the offset of the existing rotors is a perfect fit for the ATS caliper. My 2006 Delphi JE5 rotor is actually too large...it is 323mm diameter and too thick also. JE5 components changed from 2006 to 2009. In 2006 they were a Delphi design. In 2010 the caliper was Mando and the rotor was a GM design.
Lastly, I'm a little worried about the clearance to my wheel spokes. Some of the stock wheels will interfere with the caliper. One has only 0.8mm clearance, but I have aftermarket wheels with thin spokes and that may give me the clearance I need. I will know more next week when I can test fit all the parts. I've ordered 3mm and 5mm spacers to see which may work.
Update: Have all the parts now and the calipers I bought off Ebay came with virtually new pads so I'm all set there. Rotors were easy to get from Autozone at $50 each. At this point I'm almost certain I'll need the 5mm spacer. I just hope it's enough to give me at least 3mm of clearance to the caliper.
394898
394906394914
kzx03p
06-20-16, 11:57 AM
Did a test fit of the caliper and found that it takes a 5mm spacer for the wheel to clear the caliper and that will leave me with about 3mm of clearance. That means I'll have to get longer wheel studs too. Original studs are #9595178. +4mm studs are #9595179.
397961
eddyg
06-20-16, 05:57 PM
ATS calipers are a great option if you cant fit the 14" rotors on the car. BTW: Brembo says 3mm is the min clearance, so you are good to go!.
targetSTS
06-21-16, 02:15 AM
As I already mentioned in my post: i installed 10mm spacers for my setup to place caliper correctly centered to oem ats brembo rotor.
studs 9595179 not long enough for +10mm. I found new studs not oem.
hoses was bent, nothing was replaced. ats hoses won't fit. I will make photo for you when I get my car serviced
kzx03p
07-18-16, 02:58 PM
Front ATS Caliper upgrade completed on my STS. Here's what I used:
The ATS J55 Calipers
24 in Long - 4 AN Hose - 4 AN Straight Female to 10 mm Straight Banjo - Braided Stainless - PTFE. 46440-24
4 AN to 7/16-24 adapters to connect the hard brake lines to the jounce hoses
Banjo Bolts and washers from Earl's
New M14 caliper bolts PART#11570092 from the ATS (STS used M12 bolts).
5mm wheel spacer plates from Ebay
Longer wheel studs part#09599302 (2016 Cadillac XTS)
2009 STS JE5 (2nd design) rotors (2006 STS has 1st design Delphi JE5 rotors which don't work with the Brembos)
9/16" drill - Air hammer - bleed kit.
402794 402802
http://uploads.tapatalk-cdn.com/20160720/f3b060a21e26bf5c0549d75888542269.jpg
402810 402818 402826 402842 402834 402850 402858
Before image of 2006 STS with JE5,
402866
kzx03p
07-18-16, 03:18 PM
Studs removed with air hammer (super easy)
Opening caliper mounting holes to 9/16 to accommodate the M14x2 bolts (scary at first because done by hand on car instead of drill press, but turned out well
Installing longer studs using washers, nut, and air impact gun
Studs installed
Rotor, 5mm spacer and wheel pilot installed
Caliper and bounce hose installed, and brakes bled (rotor was painted with black Zinc-Chromate in areas to prevent corrosion - do not paint mounting surfaces)
Installation complete.
402874 402882 402890
http://uploads.tapatalk-cdn.com/20160719/f6d7e75eeaf20983c968319a49c48445.jpg
http://uploads.tapatalk-cdn.com/20160719/15761bb32ab6634de1577a8e68e11063.jpg
http://uploads.tapatalk-cdn.com/20160719/606e587f39f909318b8d8fc7fd46f491.jpg
http://uploads.tapatalk-cdn.com/20160719/f4576557de59822b1e0707e8c60e253d.jpg
http://uploads.tapatalk-cdn.com/20160719/42afddc5bc36d2a11e3e0087de6a02b2.jpg
http://uploads.tapatalk-cdn.com/20160719/77568016ae5afef67337784f7c5db67b.jpg
Used existing bracket to fix jounce hose to knuckle. Adjustments to attachment point were made to prevent tire/wheel contact during turns. If I had a choice, I think shorter 22" hoses would have been better. Now I have very nice looking brakes with a firmer pedal, and no rattles. Took about 2 hours per side to install.
http://uploads.tapatalk-cdn.com/20160719/cb8e59778d79fa51f3e3e958c46f27b2.jpg
Time to drive and enjoy!
Ludacrisvp
07-19-16, 10:29 AM
Why did you need longer brake hoses?
kzx03p
07-20-16, 07:33 AM
The old hose which includes a long custom metal end fitting won't work with the ATS Brembo caliper. The caliper port location and orientation are different.
kzx03p
08-05-16, 02:09 PM
J55 Brembo Retrofit update: Mileage readings have improved by about 3MPG. The old Delphi slider calipers must have been creating a lot of drag! Pin and pad rattle have disappeared as well. :cool2:
eddyg
08-10-16, 05:42 AM
"The old hose which includes a long custom metal end fitting won't work with the ATS Brembo caliper. The caliper port location and orientation are different".
Do you have the left and rights swapped?
STS spec versions of Brembo calipers have the correct leading/trailing piston set up and are designed to mount in front of the axle.
kzx03p
08-15-16, 07:45 AM
Yes, they are swapped because of the need to keep the bleed ports at the top. Will have to live with the potential consequence of excessive taper wear. However, since the pads are symmetrical I can monitor it and swap pad positions inside each caliper periodically. The ATS calipers have an "open window" so I should be able to do this without removing the caliper.
Alternatively, I could move the bleed ports to the opposite ends of the caliper where there are plugs now. This would allow me to swap back the left and right sides and would take care of the issue entirely. But I've heard that the red Loctite they use cannot be easily removed so I don't think I'll try this.
...so I will do this: swap back sides and then bleed with ports facing up then install back onto knuckle. Ports will be facing down, but not until after bleeding so it should be okay.
Update: I have swapped the calipers so LH is on Left and RH is on right. It was messy, but I did it without re-bleeding. Was careful not to get any bubbles in the connections. Brake feel is the same so I think it was successful. I'm so happy with the results of this swap that I'm thinking about changing out my sliding calipers on my '05 Corvette with Wilwood fixed calipers. Should be fun.
