: Where to find suspension code for 2008 Escalade EXT
PhilD1
11-14-12, 09:20 PM
Can any one tell me where to find suspension code for 2008 Escalade EXT. I have checked around even using VIN# and there are so many codes assosiated with Escalade shocks. Need front shocks. It does have Electronic Road Sensing Suspension. All I see on shock is LF7
Thanks,
PhilD1
Aerohokie
11-20-12, 12:47 AM
Thanks,
PhilD1
The codes for your suspension should be in the glove box. There'll be a sticker with all the RPO codes that you can use to decode it. There's a thread on here with most of the 2008 codes listed. You can compare this to Rock Auto or run a search to find your part numbers.
Aerohokie
11-20-12, 02:13 AM
I found another way. Go to gmpartsgiant.com and search by vin number. For me it returned the exact part number except for the first 2 numbers, but those should be 25 for shocks. You can verify by searching rock auto and find the full number, they usually have the best prices.
PhilD1
11-20-12, 07:42 AM
Aerohokie, thanks for the information. "gmpartsgiant.com" is a good site. but actually found them cheaper at a local dealers web site (Buy-OEM-Parts.com) with a great price $296 and Rock auto doesn't even carry OEM GM part code 19209555 (6JR & 7JR) or replacement for this vehicle.Delco # 580-375. Hope this may help someone in the future.
Those codes totally confused me. A bunch of numbers.:crybaby:
Submariner409
11-22-12, 02:34 PM
.......... and you can enter the VIN into www.compnine.com (http://www.compnine.com) - case specific.
It's a subscription site so you get only one freebie/day. Get your readout, use the lower section to check out your car's build numbers, and save it all to a folder on your hard drive. Don't hit the < key or it will probably kick you out until 24 hours from your load time.
