: Wheel Offset question
jeph054
11-13-12, 07:45 PM
I've been looking for a winter wheel option and I found some new alloy wheels that are the same rim size, width and bolt pattern. The problem is the OEM offset is +42mm and this wheel is +51mm. Can anyone confirm that this difference in offset is insignificant? It seems to me that it souldn't make a big difference.
I8URSVT
11-19-12, 09:58 PM
10mm spacer and they will sit as if they were stock.
CoSteve
11-20-12, 11:57 AM
what did you find?
AAIIIC
11-20-12, 02:58 PM
Go look at your car. Will everything clear if the wheel/tire is moved inboard 9mm? I think you're going to be getting awfully close to the knuckle.
Once he installs longer studs, of course.
what did you find?
Yeah, what he said!
jeph054
11-24-12, 03:46 PM
You guys all are right. I would need the spacer and longer studs...Eff that! I found a set of Stocker wheels with a little road rash and the TPMS for 500 total. I lucked out. So now I will slap a set of LM-60's on there and I will be good to go for the next 4-5 years.
