: Wheel wobble and pulling to the left on acceleration...
John P
11-12-12, 12:58 PM
Noticed this getting worse, Wheel wobbles/vibration at 50-70 maybe more, and if i accelerate hard it pulls to the left?
Any idea what i should check? I thought wheel balancing but that all seems fine.
the cadillac man
11-12-12, 01:53 PM
Have the wheel balance checked and the front end aligned
If the wheel balance checks out fine then it may be a broke belt in one of the tires
Having the front end realigned should fix the pull to the left
osure
11-12-12, 02:50 PM
Also jack up that tire move it side to side see if there is play if so it is hub assembly
Good luck
