View Full Version : 2012 CTS-V - PlastiDip Project on Front Grills...
houstonTT
11-11-12, 06:11 PM
So the wife was out of town and me and my 15 year old son were bored....so off to the store we went, cans of PlastiDip later, this is the result. Looks great, but has a bit of a texture to it, I was hoping it would be more smooth (like paint)....will that be the case once it dries some more?
We took the "right" route and pulled the front bumper...man what a PITA it ended up being with all the darn clips underneath!!!!
BEFORE:
http://i8.photobucket.com/albums/a35/houstonT/75F8C914-CCC0-44B1-B482-3558AE65448A-11226-000004AB67F9719A.jpg
http://i8.photobucket.com/albums/a35/houstonT/81836501-937F-4BA2-A64D-746391AE34F5-11226-000004AB5818E616.jpg
DURING AND AFTER:
http://i8.photobucket.com/albums/a35/houstonT/D132C48F-0C10-452E-8A36-C2C6679D2188-1772-000000D9622543F9.jpg
http://i8.photobucket.com/albums/a35/houstonT/E5BE4D03-A1EA-4C38-A46B-A979B9F4FE50-1772-000000D9683A9812.jpg
http://i8.photobucket.com/albums/a35/houstonT/18F3D1D3-6515-4EDC-982D-B3C1D424D5E6-1772-000000D96FD3C398.jpg
http://i8.photobucket.com/albums/a35/houstonT/3EFBD6FD-9E37-4092-BABC-9E8DEBF2B3DC-1772-000000D97759CB54.jpg
http://i8.photobucket.com/albums/a35/houstonT/91ED0791-0D5E-41D1-BE4E-0A954669CAB7-1772-000000D9823641CC.jpg
http://i8.photobucket.com/albums/a35/houstonT/B2F152AB-60F6-40F7-87B7-542CD7EA34BD-1772-000000D9885C4291.jpg
Has No Left
11-11-12, 07:55 PM
Looks great...did you need any special tools to get the front clip off?
Vwagon2012
11-11-12, 08:39 PM
Do the front splitter under the grill. If you don't like it peel it off. Black looks good with the white. Good job.
bolt007
11-11-12, 08:43 PM
The satin Graphite wheels will finish your look!! You will love them!
houstonTT
11-11-12, 09:54 PM
Has - no just a flat head small screw driver and some patience and a few cuts!
B.J. - man I can't wait!!!!!
Peter
houstonTT
11-12-12, 10:08 AM
You can see a bit of the rough texture here, did I not wait long enough b/w coats or is this just the texture of the PlastiDip?
http://i8.photobucket.com/albums/a35/houstonT/9278E8E6-86BA-47F6-B6CE-0D78920EBA16-2771-00000153F4F8C6CF.jpg
qictrk
11-12-12, 06:03 PM
Yours does seem to have more texture than mine. Like you said, maybe you didn't wait long enough between coats. Mine has a slight texture to it. I can't believe you pulled the front clip off. Your a gluton
for punishment. I put some paper and rags between the front bumper and where needed. Used a long screw driver to shove where needed. Oh well, its done and yours looks great. Cecil...............
qictrk
11-12-12, 06:03 PM
Captain McFunk
11-12-12, 06:44 PM
you sprayed too far away. also, was hit humid/hot? mainly thats from the plastidip drying before it hit the surface. looks good! looks familiar ;)
Stillborn
11-13-12, 02:09 AM
nice job. kudos from a white diamond fan as well.
http://i154.photobucket.com/albums/s261/zx9mic/WP_000498.jpg
http://i154.photobucket.com/albums/s261/zx9mic/WP_000495.jpg
Xaqtly
11-16-12, 01:38 PM
Mine isn't that textury, it's pretty smooth. I used 4 coats and waited 15 minutes in between coats. I also sprayed relatively close, and while the first coat was light, the other three were decently heavy.
http://www.xaqtly.com/ctsv/redip1.jpg
http://www.xaqtly.com/ctsv/redip2.jpg
kellerk23
12-26-12, 08:30 PM
I blacked out my 08, I'm about to spray the whole car matte black with plasti dip! I'm in Atlanta and about to also do my friends cars can't wait!
LitiGATOR
12-26-12, 09:21 PM
Can I do my front grill without having to take the bumper off?
kellerk23
12-26-12, 10:49 PM
Yes but you will have to tape off any thing you don't want to spray! Oh and make sure you put cardboard or a sheet behind the grill so you don't spray the radiator or trans cooler.
stogieman
01-10-13, 01:01 PM
I like the look,, I'm hesitant to try it,,and it would be a massive job to remove it from the grill work...I have one question,,does this stuff chip or peel?
Jerry in Minnesota
kellerk23
01-10-13, 01:09 PM
Well mine hasn't! I've had mine for months! I've taken long road trips and washed it in a car wash and nothing has happened to it so far.
thebigjimsho
01-11-13, 08:36 PM
16 months of no chipping or peeling for me...
dons
01-27-13, 01:04 PM
I like your car, looks great. I have a question, did you use flat black or gloss? I am thinking about doing my grill as my V is pearl white. Thank you. DonS
Bigreese
01-27-13, 11:24 PM
All chrome blacked out
103010http://i1211.photobucket.com/albums/cc437/big_reese/BMW%20convertible/F1623CEB-9E1B-47FD-A877-7C5C1A75F278-626-000000822E0F9572.jpg
Stillborn
01-28-13, 01:00 AM
matt black plasti-dip on the chrome & nightshades (tm) buffed out, and cleared on the rear lenses.
needstires
02-02-13, 09:47 PM
Where do you get plastic dip ? Home Depot and does it come in a spray can or brush type
thebigjimsho
02-02-13, 10:49 PM
Yes. Spray can.
WrapFactory
02-03-13, 03:38 PM
Only time I've had a texture like that happen is when the cans of plasti dip are a little to cold "like under 60 degrees", normally I will take a heat gun and warm the cans while shaking, give a really nice smooth finish. What was the temp when you did it?
Stillborn
02-04-13, 03:59 PM
plus 1 on the cans being room temp. 70* and also you have to be patient in between coats. i waited 15 mins between every round. (took the kitchen timer to the garage)
Bababooey
03-04-14, 03:33 PM
I have a Raven '11 CTS 4. First time out on this with the dip and I am considering the Gun Metal Gray (too light?) or Matte Black. Open to suggestions!
Slizzo
03-06-14, 11:19 AM
Good thing about it is if you don't like it it is easily removed.
I'd say give it a try!
SammyW
03-06-14, 04:50 PM
Has anyone actually removed Plastic dip? Not really wanting to buy another grille set if I don't like it.
OakleyCTSV
03-08-14, 12:55 PM
Using goo gone allows it to be removed as easily as painter's tape. It's great.
leroy_ctscoupe
04-23-14, 05:58 PM
Looks like one hell of a project but man, that looks good!
BEarle
04-25-14, 12:23 AM
Did you remove the grill when dipping?
cgperry
05-26-14, 08:15 PM
These pics were great. This weekend I did my emblems and front grills and am really pleased with how it turned out - everything really pops now against the white diamond.
One quick question for everyone since this thread is kind of old now and so I assume you guys have some time on your finishes: What do you use to clean dead bugs off the grill? I know the dip stands up to pressure washing, but SC has some evil insects and I normally need chemicals and/or some pretty heavy scrubbing to get the carcasses off. I'm assuming that would be bad for the dip, so what do you guys use/recommend?
Thanks!
