View Full Version : will 1963_ 1970 c10 5" drop springs fit 05 escalade
SaulT
11-11-12, 12:50 PM
I found some rear drop springs of an 63 c10 they look like they might fit my escape but not sure, anybody know if they'll work?
Meant escalade not escape
6lbsofSound
11-11-12, 07:41 PM
No they will not work. Even though they look similar the spring rates between the a c10 and an escalade very different.
SaulT
11-12-12, 12:53 AM
So it would be like i don't have springs basically?
the cadillac man
11-12-12, 10:08 AM
It would be like a low rider which will make it looks as if you slammed it
6lbsofSound
11-12-12, 12:53 PM
Spring rates are different due to the weight difference between a c10 and the Escalade. Springs from a c10 will flatten like a pancake under the weight. There a few companies that make drop springs for an escalade and go further with choices stock air suspension or swap to non air shocks.
SaulT
11-12-12, 06:06 PM
Ok, well I'm trying to get it to where the tire is right under the wheel well but i only find 3"drop spring
Yall got any websites or know someone where i can get either smaller shocks or 4 to 5"drop springs?
the cadillac man
11-12-12, 07:27 PM
Not good having it so close to the wheel well as if it hits you wouldn't like the results
6lbsofSound
11-12-12, 08:58 PM
Is yours 2WD? You can get a 5" drop but only on a 2WD. With 4WD the shafts and u joints are way to stressed passed a 3" drop.
SaulT
11-12-12, 09:01 PM
Yeah mines a 2wd i have 26s on it and the front i have it close to the tire and want the rear to match you know
6lbsofSound
11-12-12, 10:09 PM
McGaughys has the 5" drop you are looking for.
BillysBowties
01-24-13, 02:55 PM
If you still have the 5" springs from the c10 I would be interested in them, I know we can't deal on this forum but there should be a way to discuss this. Thanks in advance
