View Full Version : keyless entry issue
l8agin
11-10-12, 06:18 PM
My 2 remotes aren't working. Thinking it was the batteries, I changed them out and they still didnt work. I found directions on how to program them for my 03 and it worked, kind of. I can program one remote but as soon as I try and program the other remote, the first remote stops working again. So basically I cannot get both remotes to work at once. Any suggestions?
the cadillac man
11-10-12, 07:06 PM
When programming you have to do both remotes at the same time first the driver 1 then the driver 2 and then when you are through you can finish the rest of the steps
rfishoutofwater
11-10-12, 07:52 PM
This is true. Anytime you add or replace a remote you need to reprogram them all. You can have up to 4 remotes. Just did this a few months ago.
l8agin
11-23-12, 05:21 PM
Just an update. I ordered a new remote and now I can get two to work at the same time. Dont know what the problem is with the original remote, but all is well now.
the cadillac man
11-23-12, 05:44 PM
Could be bad battery or the remote is wearing out due to age
jnrsesv
11-23-12, 08:59 PM
I8again, thanks for the update.
rfishoutofwater
11-24-12, 01:37 AM
You might also want to check the battery connection on the remote. My battery was a little loose and after a few days the remote wouldn't work. Bent the tab in a little and bam. No more problems.
l8agin
11-24-12, 09:31 AM
The strange thing is the second remote would work fine, cept that after programming it, remote 1 would stop working. And if remote 1 was working, remote 2 stopped working. Individually, both worked fine. With the new remote, i now have 2 working remotes at the same time. Weird, right?
My pleasure
the cadillac man
11-24-12, 10:20 AM
My pleasure
It might had something to do with the programming but I am glad you got them working
TLMC
11-25-12, 05:00 PM
Clean the contacts at the circut board. They get a build up of carbon.
the cadillac man
11-25-12, 08:03 PM
I tried that on mine once and it works
