: Boiling Power Steering Fluid.
Silver Sled
10-29-12, 04:32 PM
Alright, on my first track day, my power steering fluid boiled over and the power steering pump failed. Dealer replaced it under warranty and this last weekend I did another trackday and the res was boiling over all day. This time I went with Redline heavy duty fluid but to no avail. Has anybody else run into this problem? And bow are you addressing?
cruiser68
10-29-12, 04:46 PM
I'm running Lucas Power Steering fluid and I have had no issues at all in 3 track days. Sorry it doesn't help you at all but I would have figured you would be all set running the Redline. Thinking there might be something going on in the rack itself especially if the pump has been replaced.
thebigjimsho
10-29-12, 06:22 PM
Problems with the power steering cooler?
jenlain
10-29-12, 07:58 PM
Running stock fluid and have never had an issue.
Silver Sled
10-29-12, 09:19 PM
Hmm. I had two V coupes at the track and they both did it to me... There is a power steering cooler?
M5eater
10-29-12, 09:50 PM
There's no way you should be boiling P/S fluid.
the V has a tube and fin cooler. It's more than adequate for track use even. Check the cooler (or replace it) in case it's clogged, damaged or airflow is blocked.
It's the small one directly behind the front cross member. Can't miss it.
baabootoo
10-30-12, 12:55 PM
Yes, my fluid has leaked a little from the cap, but that was it. Did they confirm the fluid was boiled after doing an analysis? It's still a type of hydraulic fluid, which would have to get over 250? F to boil.
Silver Sled
10-30-12, 02:30 PM
I am making an assumption that it boiled/foamed up because it was everywhere inside the engine bay. No formal testing was done. I will check out the cooler. I was told that because of the added load on the steering pump from increased HP, this was likely the cause, and that the same issue is being seen on the new Camero's that are being supercharged. The solution apparently is a new pump by Lingenfelter I believe.
thebigjimsho
10-31-12, 12:41 AM
I'm tracking in hot conditions with 630hp and no issues with PS...
M5eater
10-31-12, 09:53 AM
I've never heard of this happening either. Although, This is the first on-pump res P/S system car I've had too.
NAX-121
11-01-12, 05:24 AM
No Joke its a very real issue. I race in the Cadillac Challenge series and i am flushing all fluids after every 4 solid track days. There was a car that the owner had run in 7 track events plus daily driver miles and he had a pump failure at the last race at Buttonwillow. If you can feel any fine metallic debris in the fluid your screwed. Ive just decided to bite the bullet and stay on top of the fluid issues cooking. As far as the power steering overflowing just cut a piece off a shop rag and wrap it around the cap then use a ziptie to secure it. Good luck and have fun tearing up the track.
6104696
11-01-12, 07:11 AM
I had some leakage out of the PS reservoir cap on my V1 on a couple of track days. No failures though. Only one track day on the V2, and no leakage issues.
winstonlv
11-14-12, 07:20 PM
You don't go fast enough to have any overheating issues
NAX-121
11-15-12, 02:05 AM
:nyanya:[QUOTE=winstonlv;3142568]You don't go fast enough to have any overheating issues
I didnt see you registered for sunday. Whats up??? Too bad cause id enjoy watching you keep up....or lets say try and keep up:lol:
You got an 09 V2 right? Im sure by now you figured out how to handle it and if you pull the "I dont want to scratch it or ding it " bitch out excuse then from now on your name is Nancy! So are you going to put your big boy pants on and come down to fontana??? Or is Nancy going to stay home and play bridge whit the girls?? LOL just messing with ya bro. How are ya?
