: High gas mileage usage!!! Help!!!
10-18-12, 06:27 PM
I own 2000 Sport, using highest octane gas and my gas mileage horrible only getting 210 miles per tank or 14mpg !!!!
what i can do or what need to be change to get better gas mileage
I already done:
----year old oem spark plugs, injectors was handy cleaned (not cleaner in fuel tank)
----2,4,6 cylinder coil was replaced due to misfire
----fuel filter like 1,5 year old (it's should be less the 15k mile on it )
----both O2 sensors that before cat. were replaced due to check engine light
----seafome air system few times already since i got this car (curenly exhaust coming out fine)
----recently took car to mechanic (had some problem that were fix) he tasted fuel pump also and it was working fine
----using Castrol GTX 10w-30 oil since got this car
----just replaced air filter (my old one was not even dirty but i replaced any way) thought it will help - but it didn't
No check engine light !!!! Car running great!!!
Also im not crazy driver usually trying to keep rpm less than 3000
What can be wrong or just not working right that can makes my car eat gas like that!!!!?!?!?!?!?!?!
Any ideas????????? Please Help!!!!
Thank you
10-19-12, 03:37 AM
do you allways get your gas at the same place?
10-19-12, 02:22 PM
Have you checked for a bad FPR?
