: 22' Tire sizes for 05 STS
jenninc1
10-17-12, 11:08 PM
I have an 05 STS AWD. Im about to order the Lorenzo WL32 in a 22x8.5 with a 40 offset (need high offset for AWD). This should tuck nicely. My question is tire sizes. the car came with 255 45 17's in the rear and 235 50 17's in the front. Initially i was thinking about going with a 245 30 22 on all four tires (in order to rotate tires). But with the high off set tucked deep in the wheel well I was considering going with a 245 30 22 in the front and a 265 30 22 in the rear, just so the tires wont look so narrow when you view the car from the rear. I also heard that the 265 would give me a little bit better ride because your putting more rubber on the road. I dont drive this car daily so tire rotation is not as important. Just wanting to get some quality opinions from the guys currently rocking 22's on their STS. All the old school haters with uninformative negative comments please stay OFF me thread!!!!!!
DarkMingBlueSTS
10-17-12, 11:35 PM
I agree with you on wider rear tires but a 265/30/22 will be slightly taller than a 245/30/22 causing the car to "rake" more and in my opinion they have too much of a rake from the factory. It will be a very small amount but it will be there so be careful of that...
curtc
10-18-12, 12:18 AM
Should be the same 30 sidewall height...just different widths.
DarkMingBlueSTS
10-18-12, 06:44 AM
the sidewall height/number is a percentage of the width/number...so tires with the same sidewall number but different width numbers will have a different height.
eatyoursandwich
10-18-12, 04:16 PM
Decent choice in wheels and I have a set I use on the Cayenne from time to time so I won't rip you too hard for putting them on an STS, but I say get the 10.5's on the rear with a 25mm spacer, stretched 265, slam it, and get some adjustable control arms for the negative camber you're going to have to run. Practical? No. Comfortable? No, but do it anyway.
Charles Warren
10-19-12, 07:07 AM
i have 265 30 in the front and 285 25 in the rear but i wish it was a 315 25 in the rear and a 265 25 in the front but they dont make em in that size. that pearl sts looks nice, butler tires does good work and is known for it
ITSQUIK
10-19-12, 09:22 PM
If its AWD, don't the tires need to be the same height front & rear. I'm not familiar with the AWD, so don't bash me. I have 295/25/22 rear with a 255/30/22 front & it's hugely obvious the widths are different. The height is dead even though if the height of the tire is a concern for AWD.
DarkMingBlueSTS
10-19-12, 09:32 PM
25's...sick sidewall height!
EChas3
10-19-12, 10:58 PM
An AWD has 3 open differentials. The issue is with the traction & stability systems. Proper operation requires the same circumfrance tires on all wheels.
Some members owning a RWD STS have reported issues with tires different than OEM.
jenninc1
10-21-12, 03:57 PM
Are you running a 22' wheel? Is your car awd? does the 265 30 in rub in the front?
EChas3
10-21-12, 09:34 PM
I know 255/45-18 don't rub in front on an AWD w' MRC.
Charles Warren
10-22-12, 02:02 PM
Im rwd and yes 22s. Im thinking of going upto 24s but only 2pc or 3pc wheels so ill save up for them or keep ring my gfg's
gsanchez408
11-01-12, 06:41 PM
running 245/30/22 nitto invo front 8.5 inch rim and 265/30/22 invo rear 10 inch rim. i love how it sits, no suspension modification full u-turns no rub EVER. did a lot of research to make sure i didnt have to do anything except put them on. i believe my offset is 40 also rwd sts v8
