: 2005 Escalade (ESV) Power Seat Non Functioning (Free Fix W/Pics)
jnrsesv
10-15-12, 08:22 AM
Symptom:
Lost all power to drivers seat only. No forward/reverse, tilt or bolster/lumbar. The passenger side works normally.
First things I checked, obvisously fuse, but alas I have looked in the manual and online, couldn't find location. I did come across a couple of circuit breakers, one under hood and one inside cab, both checked out ok. I then moved my attention to the underside of the drivers seat, what a nightmare. All visable wires looked connected and unscathed.
Under Dash Circuit Breakers:
http://i782.photobucket.com/albums/yy103/jnrkara/2005%20Escalade%20ESV/power%20seat/CircuitBreakerCover.jpg
http://i782.photobucket.com/albums/yy103/jnrkara/2005%20Escalade%20ESV/power%20seat/30Amp.jpg
I then decided to look at the Power Seat Module itself, once removed from the lower seat cushion, I found its a sealed unit. I decided to swap out with the passenger to see if the module itself failed. The working passenger side Power Seat Module did not work on the drivers side. I replaced both back to their proper places.
http://i782.photobucket.com/albums/yy103/jnrkara/2005%20Escalade%20ESV/power%20seat/DriversPowerSeatModule.jpg
Moving along, I went to the ole stand by, Google. There were many sites that recommended going to a dealer and having the module updated with new software, umm at the time I did not consider this an option. One site had mentioned to pull the 30 AMP circuit breaker for 30 seconds to reset the modules, that did not work. I continued on, many, many pages into Google, I found a site that someone posted "chaffed wires" at main power connection. Ah ha, so I contorted myself between the rear seat and drivers seat where I found the Main Power Cover, I removed it to find the power wires (no chaffed wires), I wiggled the two harnesses, and tried to move seat, BINGO loose wires at the main connection. I used small zip ties to secure the connectors together.
http://i782.photobucket.com/albums/yy103/jnrkara/2005%20Escalade%20ESV/power%20seat/MainPowerCover.jpg
http://i782.photobucket.com/albums/yy103/jnrkara/2005%20Escalade%20ESV/power%20seat/MainPowere.jpg
Drivers side seat, now is in proper working order, forward/backwards, tilts, and bolster/lumbar
mitch2264
10-15-12, 09:05 AM
Excellent write up!! Thank you for taking the time and energy to post this! Google can certainly be a friend--yet daunting at the same time :).
Thanks again!!
Mitch
the cadillac man
10-15-12, 12:23 PM
This needs to be in the FAQ section if a admin sees this please make this a sticky
jnrsesv
10-15-12, 02:38 PM
Thanks for the thanks Mitch and your welcome.
Hope it helps someone out someday.
Phranke
10-22-12, 01:31 AM
I want to say thanks also, my seat hasn't worked for about a year now and it wasn't so bad for me cause it was stuck in my spot, however, the bad part was that the heated seat didn't work. Took me about 5 min to get it working again, that includes the time it took to read the post! Thanks
jnrsesv
10-22-12, 02:11 PM
Phranke thanks for the thanks.
I am glad that I was able to help you out.
EscaladeBob
03-23-14, 08:32 PM
Thank you very much!
this is Exactly what was wrong with our truck!
-Bob
Scottparrish
07-17-14, 10:33 PM
Thanks so much. This fixed my wifes vehicle.
Thanks for taking the time to post this
Symptom:
glowe
10-02-14, 04:28 PM
This solved my Front Driver's seat issue ,,, Huge Thanx !!
Symptom:
bumboy
10-21-14, 11:26 PM
Hello friends, I have a 2006 Escalade and the forward/backward on the drivers front seat stopped working but everything else still works which includes tilt, bolster/lumbar/heated seats.
I'm thinking maybe just the forward/backward motor burned up? please help thank you.
the cadillac man
10-22-14, 02:32 AM
Hello friends, I have a 2006 Escalade and the forward/backward on the drivers front seat stopped working but everything else still works which includes tilt, bolster/lumbar/heated seats. I'm thinking maybe just the forward/backward motor burned up? please help thank you.
Pull the harness for the motor and carefully apply 12 volts to the terminals (there is two plugs one for the motor and one for the position sensor)
Either way the whole seat track has to be replaced
goodpl23
10-21-15, 12:38 AM
Hello friends, 2007 esv driver seat stopped working suddenly along with brake pedal wont adjust. Also no heat or cool to either seat. However passenger seat does move fwd bckwd up/down. Any suggestions.
the cadillac man
10-21-15, 02:42 AM
^check the connections at the driver's seat module(under the front of the driver's seat)
Also check the wiring for any chafing or damaged spots
If the connections and wiring check out then you may have to replace the seat module(as the pedal controls work through it)
goodpl23
10-21-15, 09:27 AM
Okay great. I will check thanks. Crazy thing is that took it to local dealer and they told me i needed some computer module to fix this. Quote of 2000. I hladly declined.
the cadillac man
10-21-15, 10:58 AM
that is highway robbery
I have priced the seat module and it's nowhere near that(even with labor)
I would go somewhere else
It's possible you can get one at a junk yard or salvage yard for a LOT less as it doesn't really need to be programmed to the truck as long as the doner truck has the same features(a Yukon Denali module will work)
goodpl23
10-24-15, 06:06 PM
Thanks again
goodpl23
10-24-15, 06:09 PM
Do you if its possible to buy a new harness. My dad looked at it and I believe the dealer cut some wires and did something to the harness under the passenger seat
godsdiablo
10-24-15, 06:13 PM
Is it possible to solder the wires together? I'm sure you can go to a junk yard and get the harness cheap or head over to the dealership and get a price on the harness I'm sure they sell that
the cadillac man
10-25-15, 01:58 AM
Yes you can buy the harness but sheesh it's outrageous on the price(I know I already priced it back of this)
I would solder the wiring back together and see if everything works afterwards as the other poster has mentioned(DON'T forget to heat shrink the work to prevent any short circuits)
godsdiablo
10-25-15, 09:24 AM
If you double heat shrink then solder and then electrical tape them you won't need a harness it'll last a lifetime
goodpl23
10-27-15, 03:25 PM
Thsnks again. For the help. Let u know how it goes
goodpl23
10-27-15, 03:27 PM
Thank you. I just like to be well informed as u know sometimes they like to take advantage of women. Lol. But seriously i greatly appreciate the help
goodpl23
10-27-15, 03:50 PM
Sorry to be a pest. But when u say seat module. Is it the driver seat memory module? Or something else. Just trying to locate the correct part online to order.
the cadillac man
10-27-15, 07:38 PM
Yes
It's located under the front of the driver's seat
tquick
04-03-16, 09:45 PM
I have done 3 of these. The power in the molex plug under the seat burns up and all I do is patch the wire around the molex with a but fitting. Did mine last year and my sister in laws 4 years ago no more issues. look for a burnt wire into the molex will be black and crusty.
also the dealership said it would be about 2500 to fix and replace modules. Should have let them do it after I video my fix and put it back
Last picture he posted look at wiring correctly on molex plug. If one is burnt up clip on both ends where it goes in and out and route it without using molex plug and crimp with butt connection... Done 2 like this
jnrsesv
04-03-16, 11:19 PM
Thanks for the tip. In my vehicle nothing was "black and crusty", as shown in "his" last picture.
Hmm, I am kinda at a loss here. I would have loved to "video" my fix and charge $25.00 or $2,500.00 as you stated for my free fix that I had taken the time to document and post here. Gee I wish I would have charged something at over 16,300 "looksies" at this thread. Even at $25.00 for my free fix, my math comes up to $400k.....Dummy me.
Thanks for the respect "he". I post here daily to contribute to this forum. I take it as a bit of disrespect/insult being refereed to as "he", I guess its my upbringing.
But again thank you for making somewhat of sense in your first post. Welcome to the forum. Enjoy the board and remember to have your camera handy when you post your DIY's in the future.
the cadillac man
04-03-16, 11:42 PM
^ take it easy on the new guy
We all make mistakes
Been there before
jnrsesv
04-03-16, 11:58 PM
I believe that I was being exceptionally easy. Lets see what "he" brings to the table in the future.
the cadillac man
04-04-16, 07:15 PM
Oh boy just don't get into trouble
goodpl23
08-04-16, 01:09 PM
know this says 2005. But I have a 2007 so have they moved the seat memory module. Because dealer told me its under the passenger seat not driver. Also, they (dealer) cut the harness under the passenger seat. By any chance do anyone know the correct part number for the seat memory module as well as the CCSM they say I also need to replace.
Sorry if this has been addressed already
N9LO
08-04-16, 02:27 PM
You may want to post this in the 2007-2014 Escalade forum as this one covers 1999-2006 Escalades but if someone here knows your answer they will post it anyways.
