: High speed wobble
Bstubbs
10-14-12, 07:01 PM
Need some help. I was at the track today and I experienced high speed wobble coming from the rear end. I was running my pilot sports at about 26lbs of pressure. Funny thing is I have actually gone faster on the highway very recently with no wobble. I was also in sport mode on the suspension and comp mode on the traction control. Any clue what this could be?
jzchen
10-15-12, 06:25 AM
Usually you need higher pressure for speeds over 100 mph. 26 lbs is 6 lbs lower than recommended for normal (<100 mph) conditions. I would check for tire damage...
RGaret
10-15-12, 06:32 PM
What happens if you keep the higher pressure in the tire all the time. Sometimes I exceed 100 for brief periods only.
McGuffy
10-15-12, 08:13 PM
The car was designed to drive that fast. 32psi is the way to go unless you're under some extreme (track) conditions.
ClarkkentCTSV
10-16-12, 12:32 AM
Did you refill the tire to proper recommendation? I'm sure it was the low tire pressure in the tires. Will help with traction, but get wobbly at high speeds.
odla
10-16-12, 12:54 AM
I would check the lugs just to be sure.
