View Full Version : Drag radils with out sensors and dash light
Brian in GA
10-13-12, 04:14 PM
I have my extra set of rims with my DR's on and the light on my dash is on and a message appears in the info center. is there any way to turn this off?
Torxila
10-13-12, 05:24 PM
The reset button will temporarily shut it off, but you have to keep doing it as it comes on. I was told also that a skilled tuner can use HP tuners to disable it; but if you switch back to stock tires you would have to able it again.
When I run DR's (with tpms, on an extra set of stock wheels) on the street I keep them above 20psi. When I lower them to 15psi the message comes on and I just reset it until I air them back up to 28-30psi.
Good luck
George
larry arizona
10-13-12, 05:24 PM
buy some sensors for your dr rims.
Darnell
10-14-12, 02:45 PM
I wouldn't worry about it since most times my DRs are going to be below the TPMS threshold anyway.
