View Full Version : Bose Gold series speaker amp same as Bose std. ? 92 Eldo ETS
The Gold
10-09-12, 12:53 AM
Hello, I need to replace the speaker amp on the right hand side door.
Symptoms: squeal and popping sound.
Question: This is a 92 Eldo ETS with the Bose Gold series audio, which apparently has two extra speakers on the door versus the standard Bose audio without the CD player9so says FSM).
However, the specific question is, Are the speaker amps interchangeable between the standard and Gold series Bose systems without losing audio performance?
(I'd like to fetch one from the junk yard where normally the head units are pre-pulled, so you can't identify the system until after you disassemble the door panel etc.)
Thanks !!
05-14-13, 10:54 AM
I have the same issues, but with squealing in the rear amps. Did you ever figure out the fronts? I think my front drivers side upper freq is out as well.
