: Will 18" Wheels fit? - Winter Tire Setup
GEVjr83
10-07-12, 01:43 PM
I am working on purchasing a winter setup for my 2011 CTS-V and wondering if 18" wheels will fit on both the front and back. I found in shopping around that a set of 4- 255/45/18 on 18" rims is much cheaper that a 19" setup. I have the bolt pattern and back spacing all figured out, just need to know if they will fit!
baabootoo
10-07-12, 01:49 PM
Yes, but maybe only certain ones. I use Moda 18s, and they fit the front just fine. Check out wheels for a Pontiac G8 since I used mine on that before the V. What offset did you figure out? You'll need at least an 8 1/2" wheel for 255s too. Have you considered the 245/45 x 18? You can get by with an 8" wheel, and have a lot more tire choices and room. Thinner is better in the snow! I'm actually looking at the 235/50 x 18 for this winter since they can handle the load easy enough.
GEVjr83
10-07-12, 04:47 PM
I think I will look at the 245's with 8" in rims. A 40mm offset on 8" width is only 2mm inboard of the stock wheels with 24mm of extra inner clearance. Thinner in the snow is better for sure, exactly I couldn't bring myself to put a 285mm snow tire on the rear (especially for the price).
Tom Paine
10-07-12, 09:34 PM
I have 225-50-18" michelin ice. Skinnier the better in michigan snow. Car does fine.
GEVjr83
10-08-12, 07:19 PM
@Tom- What wheels are you using?
baabootoo
10-08-12, 11:53 PM
Some Sport Edition wheels will fit also.
luderchris
10-09-12, 01:20 AM
??? What Sport Edition wheels???
Oldchevguy
10-10-12, 02:07 PM
I have a set of Touren TR9 wheels in 18" with some Nokian Hakkepellita rubber in the sizes you mentioned. The dealer I got the car from had ordered them and sold them with the car. There is very little clearance around the front calipers but no rubbing. I install them in case my truck decides to break down, but prefer not to drive around with studded winter tires.
luderchris
10-10-12, 09:41 PM
Baabootoo - what Sport Edition wheels?
baabootoo
10-10-12, 09:57 PM
I have the 18" x 8" F10s, that fit my Pontiac G8 and luckily the CTS-V up front!
luderchris
10-10-12, 10:28 PM
Ok. Thanks.
baabootoo
10-10-12, 10:57 PM
I have the same as the guy above; 18" x 8" with 40 MM offset.
Scooter
10-12-12, 05:34 PM
OldChevyguy, which model # of Touren TR9 are you using? Offset and size please? None of the dealers around her want to order wheels up for me that technically don't fit according to their lists.
Oldchevguy
10-12-12, 06:38 PM
I'm out of town for work but I can check my paperwork when i get home next weekend.
GEVjr83
10-31-12, 01:22 PM
Ended up purchasing a set of 18x8 40mm offset Drag DR37 in Flat Black mated with 245/45-18 Hankook I Cept Evo's from Discount Tire Direct. They fit up and look great. We shall see how the Hankook's work when the snow flies...
iwannagofast405
10-31-12, 01:49 PM
I have CCW wheels 19x8.5 in front and 19x10 in rear. With Toyo TIR 245/40 front and 285/35 fire hawk Indy 500.for rear tires. VERY HAPPY :)
luderchris
10-31-12, 01:58 PM
Can you post some pics???
luderchris
10-31-12, 02:01 PM
Any reason you went with 18x8 and 245/45 instead of 18x8.5 and 255/45??
iwannagofast405
10-31-12, 02:26 PM
Those specs were for my 2004 CTS-V...tried to post pics but file size on my phone won't allow :/
luderchris
10-31-12, 02:35 PM
Thanks, but I was addressing GEVjr83.
GEVjr83
10-31-12, 03:55 PM
Skinnier is better in the snow. Here are two crapy pics taken with my blackberry. The picture of one fit to the front doesn't do it justice. I don't think it looks good in the picture but does in person...
I will take a few better pics this weekend and post...
iwannagofast405
10-31-12, 04:07 PM
I know who you were addressing..I was just posting my info for threadstarter...
tungsten
11-22-12, 11:15 AM
Im looking at doing the same, but I am looking for cheap, real cheap, like used wheels off a BMW/Corvette/ETC. How did you figure out backspacing and from what you purchased it seems that 40mm will work for both the front and rear. I figure as long as the wheels I find have a backspacing of 40mm or larger I can always put a spacer in to bring it back to 40mm. What about the hub bore, did you have to worry about that or did you just stick with bolt centric wheels? On the tire size can you go with a larger aspect ratio to fill in the wheel well a bit more? I have a V wagon 2011, are the specs the same? Thanks.
thebigjimsho
11-22-12, 03:53 PM
If you buy from DiscountTireDirect, hubcentric rings and lug nuts come with the wheels. All delivered from under $1G...
luderchris
11-22-12, 07:12 PM
How about TPMS sensors? I couldn't find them on the Discount Tire website.
tungsten
11-22-12, 08:47 PM
Wow, not bad or worth d&^%king around over. Thanks.
Scooter
11-23-12, 10:23 AM
Dude, get the Touren TR9 rims in 18" size, they will work and they're about $139 each. You'll need hub ring adapters and smaller nuts but a good shop will include all of that for you. Just make sure they put the wheel balance weights on the inner side of the rims and not near the brakes or they will rub, there's very little clearance.
tungsten
11-30-12, 02:21 PM
Hmm, I will have to consider them. I couldn't do nearly as well as thebigjimsho, not sure how he got the set with tires for under 1G. I was looking at camaro 2010-2013 steel wheels for 150$ for the set. It looks like all I need is a wheel spacer, the diameter clears, lug pattern works, and hub seems to work. The front face of the caliper hits the inner of face of the mounting surface on the wheel. I have no experience with spacers so I'm checking into it.
thebigjimsho
12-09-12, 07:31 PM
No no, I got the wheels alone for just under $1G. I bought the slicks separately...
DBCTSV
12-09-12, 08:38 PM
18x10 with 265/40R18 Michelin Pilot Alpin PA2's are working great for me. In Minneapolis, we got hit with a major snow storm today (6+" of snow) and the package held up just fine on my Vagon today.
Details can be found in this thread...
http://www.cadillacforums.com/forums/2009-cadillac-cts-v-general-discussion/276417-13-red-vagon-perfect-holidays.html
