: Rough idle and check engine light...
IvoryWhiteCatera
10-06-12, 11:23 PM
Me and my brother just replaced the valve covers with Saab ones, and installed a new ac compressor. Starts up just fine, but today I started it and the idle was rough and the check engine light flashed for a few seconds and went solid. Don't have a scan tool. Idle is a little rough and acceleration a bit sluggish.
elvin315
10-06-12, 11:32 PM
Check the spark plug wells. They might be full of oil. If the gromets weren't installed properly they could leak oil under crankcase pressure.
IvoryWhiteCatera
10-07-12, 11:56 PM
No, fixed that problem recently. Went to O'Reilly and had it scanned. Misfire on cylinder 6.
JohnJJO
10-08-12, 03:31 AM
there is wire going to throttle body. make sure uconnect it good ,
also clean connectors
IvoryWhiteCatera
10-09-12, 12:49 AM
It's good. Maybe it's the coil or wires...or spark plugs.
hgqguy
10-14-12, 12:13 PM
sounds like a bad coil to me.
ihad similar issue about 2 yrs ago.
IvoryWhiteCatera
10-14-12, 09:59 PM
Cylinder 6 is the only one misfiring.
olddavid
10-27-12, 12:07 AM
I just completed the same job on my car (70k) and I needed new wires and plugs to go with the cam seals to get the car completely right. Mine kept saying no. 3 was malfunctioning. I found the oil had saturated the wire to the point it would not clean with alcohol or any other solvent.
IvoryWhiteCatera
10-29-12, 04:27 PM
Thanks. I'll try that.
