: 2005 STS tail light testing
10-05-12, 03:04 PM
What is an easy way to test tailight assemblies on a 2005 sts. Can I swap connections from opposite sides to test without causing a problem.It is my outer Brake light row of lights that is out on my driver side.
Thanks for checking
10-05-12, 10:20 PM
Do you have a Volt/Ohmeter (VOM) & know how to use it?
10-06-12, 01:29 AM
Yes, they are identical. Wire colours will be different but you can go ahead and plug the connector into the lamp assembly from the opposite side for diagnostic purposes.
