: Where do you adjust Rear Camber on '06 STS
fly187
09-21-12, 03:04 PM
I have the ability to align my car myself. I own a suspension and alignment shop for 18 wheelers and I do what I can own my personal vehciles. Though it's a pain in the butt not being set up for cars. I have over 1 and half degrees Negative Camber on the left rear. I have toe set to 0. Can not find where to adjust camber on upper or lower control arms. Please help. Thank You
EChas3
09-21-12, 08:34 PM
Spec for STS4 1SG, you are within tolerance (barely). Is it a shim adjustment?
Camber Front -0.50 Min -1.10 Max 0.10 * Rear -0.90 Min -1.50 Max -0.30
Caster Front 5.50 Min 4.90 Max 6.10 * Rear n/a
Toe Front 0.10 Min 0.00 Max 0.20 * Rear 0.10 Min 0.00 Max 0.20
fly187
10-02-12, 04:29 PM
Don't need the specs, where is the adjustment made at on REAR SUSPENSION???
EChas3
10-02-12, 10:13 PM
Sorry, I don't have the shop manual. It may be shimmed.
sapien
10-02-12, 11:20 PM
Here you go, the alignment section out of the FSM -- hope this helps:
https://docs.google.com/open?id=0B59LJxuxQmYVRlhBanp3UHgzRUk
fly187
10-04-12, 02:44 PM
Thanks.
