: 04 Escalade Awd 6.0 160,000 just bought?
Je357
09-20-12, 08:27 PM
Hey fellas new here...and so far love this forum..great info here..ive been following many posts...I would like to get some advice on what i should do bout my transmision fluid...just bought this truck and it already has high milege 160,000.. dont know how the previous owners kept up with maitance...ive just changed so far.. Engine Oil , front diff Fluid, and about to do, trans case fluid and rear diff tomorrow.ive already went to dealer to do drivers side axel boot. the rubber was torn and grease was shot every where. also the service guy told me a list of other parts needed to be replaced. he said i needed " two front shocks, pitman arm, some Abs wheel sensor, not sure left letter in my locker at work. but also the emergency brake pads. :banghead:so also i had a checkengine light on..i ran that with my code reader and came up with code p0496 evap. Did reasearch on that on this lovely forum...ANY suggestions on what i should do are greatly appreciated..:cycle:
the cadillac man
09-20-12, 08:44 PM
Here is a little info on the code
http://www.obd-codes.com/p0496
Don't feel bad about the park brakes mine are bad also
PITT M3 RR
09-20-12, 08:54 PM
Being OBD2, anytime I've had issues with the evap system I took it for the smoke test. This will show if air or exhaust gas is getting out of where it is supposed to be contained or into where it should not be. Egr valve and all that...
At that mileage I'd do the air filter, plugs, fuel fliter, wires and a coolant drain/flush as well. Look at little O-rings you can replace in the system which could save you alot of money! Good luck,I'm loving my new purchase as well.
Je357
09-20-12, 09:22 PM
nice info link for that code.....as for the park brakes i want them... i dont like parking on hills ....cause i dont have them..then its hard for me to get outta park...using my tranny as a kickstand...:caddy:
Je357
09-20-12, 09:25 PM
thanks buddy will get on all that as well....what you think i should do with the tranny oil..i heard rumors of leave tranny fluid alone.
PITT M3 RR
09-20-12, 09:46 PM
Not a problem, Look into summit racing for a few of these things. I got the fuel filter for 10 or 12 bucks, a new tranny mount for 7.89, and the motor mounts are 25.89 a piece I believe. Chances are with our mileage, mine at 117K yours up at 160 that those rubber parts are worn and filtering parts have long passed their proficient stage.
As for auto fluid, I have also heard what you have. Unfortunately I have come from driving mostly manual BMWs and DSMís...this is my first big truck aside from my wrangler I modified for awhile. I really donít know. What I would do is, if the vehicle had been used for towing, chances are the fluid took a beating and ran hot many times. Take a spin, watch your gauge and see what the temp reaches and how fast. Report back and we can compare with others. If the fluids protective properties have broken down, I imagine it will heat quicker and get hotter? Give a Cadillac dealership a call or a reputable shop and see what they think. I know the gear fluids need it, but not sure on the tranny itself. Are you slipping?
I get a slight buck sometime on up or downshift rarely. Thatís why I bought the mounts from summit.
the cadillac man
09-20-12, 09:48 PM
I am the same way just ain't had the time to get them replaced(it sucks to park on hills) I have a time to get my truck out of park when I park on steep hills(which in my area is about everywhere)
Je357
09-21-12, 10:08 PM
first truck also for me ...as far as slipping i think shes alright..goin up hill from 1st to 2nd feels alil weird sometimes if im babying it. but if i give it some good peddal dont feel that shift at all..as for tranny fluid i called a shop and ask what i should do they said check the level and color if needed just add to it. i see no signs of leaks under there...i m going to do the wires plugs air and fuel filter on my vacation this week along with the transfer case fluid and rear diff..ill let u know how it all turns out...........also had a slight humm in the front end..did some research here and ppl said front diff goin bad...hope not....so 2 days ago changed the front diff fluid...shit was black with metal shavings for days in there..try to get all of it out...put 2 quarts of 75w90 mobil 1 and that hum is gone....hope all is well for that...:thumbsup:
Je357
09-21-12, 10:10 PM
yea im going to find a thread on those parking brakes cause i wanna tackle those as well while im on vaca....
the cadillac man
09-22-12, 02:10 AM
Good luck I don't think many people is willing to tackle it but I had a whine somewhere in the driveline(I think it was my transfer case low on fluid)that has went away(my truck is creepy quiet inside now except hearing the exhaust growl) since my last oil change
I went to my local dealer this time as there ain't much difference in the price of the shop I went to before.
Je357
09-22-12, 04:07 PM
yea man...just started vacation today...gonna go in on my truck tomorrow...transfer case rear diff etc..........:stirpot:
Je357
10-02-12, 06:37 PM
this is a update to the progress on my truck....ok so i changed all the fluids everywhere...i had a abs light on.... a traction control message on display ,and a check engine light on with code p0496...had a buddy of mine come over and help me out since he is a certified mechanic and got to work..we changed the purge valve on top of the engine right under the plastic engine cover..part cost 35 bucks..check engine light gone..also dealer told me my front shocks were bad...nope freaking idiots....they were good all i replaced was the front left hub assembly with abs sensor and all the lights in the cab on cluster went off...no more abs light or stability system light..so far so good..the humming noise that i mentioned i had ..my buddy told me it is my front diff..but he told me it dosent sound so bad he told me not to worry to much on it...
the cadillac man
10-02-12, 07:11 PM
You better get the diff seen to soon as it will fail if you don't.
Ps get a different dealer since they can't tell if the shocks are good or bad.
Je357
10-03-12, 08:36 PM
Dam...ima see if i can find a specialist in my area. Thanks man. Are these prone to go bad?
the cadillac man
10-04-12, 12:42 AM
If you don't keep a close check on the fluid level or a seal is bad it can happen and this is why I have both diffs checked every time I have the oil changed.
hueterm
10-06-12, 06:06 PM
Yes.
