View Full Version : need more parts
daveyhouse
09-19-12, 01:42 PM
Chris,
On the exploded view I am needing a quote on parts for the following
#142 part# **581223 (chain tensioner) Quantity 1
#145 part# **556030 (cahain tensioner) Quantity 2
#252 part# **557838 (belt tensioner) Quantity 1
This will be an order place mid next week
On a different order a couple of weeks down the road
#423 part# **555384 (oil pump) Quantity 1, and also the mounting bolts for the pump being they are torque to yield I want to change them.
These parts are for a 96 eldo Y motor going into a 98 deville delegance
Thank you for your time,
Dave
RippyPartsDept
09-21-12, 11:27 AM
Dave,
Sorry for the delay. What illustration are you getting this info from?
Cheers,
Chris
daveyhouse
09-21-12, 04:47 PM
From gmpartsgiant.com
Sorry I thought you guys had the same references. You being a supporter of the site, I would rather you get the business
RippyPartsDept
09-21-12, 04:49 PM
but what illustration(s) are you referencing?
you didn't post a parts illustration in your first post for me to know what parts you have selected
#143 means nothing without the illustration
daveyhouse
09-22-12, 01:53 PM
The first 2 parts are on this page
http://www.gmpartsgiant.com/Page_Product/PartDetail.aspx?&Make=Cadillac&Model=Eldorado&Year=1996&MakeCode=K&ModelCode=E&CatalogCode=65O&SubModel=Base%20Model&mCode=6EL57&eCode=LD8&majorIndexID=00&SupplGroup=80&minorIndexID=6M00-037&ART_SUFFIX=1&SortKey=23
illustration links off that page of near top under get info tab
Third part is on this page
http://www.gmpartsgiant.com/Page_Product/PartDetail.aspx?&Make=Cadillac&Model=Eldorado&Year=1996&MakeCode=K&ModelCode=E&CatalogCode=65O&SubModel=Base%20Model&mCode=6EL57&eCode=LD8&majorIndexID=00&SupplGroup=80&minorIndexID=6M00-021&ART_SUFFIX=1&SortKey=15
P.S. Do you have an online exploded view of a 96 eldo y motor that I could use?
I'm sorry I made this difficult.
Thank you again for your time,
Dave
RippyPartsDept
09-24-12, 04:37 PM
ok,
http://www.genmotorinfo.com/images/00/9509076M00-037.png
#142 (timing chain tensioner)
GM#12581223
$28.54 - list price
$17.84 - your price
#145 (timing chain tensioner)
GM#12556030
$51.16 - list price each
$36.45 - your price each
http://www.genmotorinfo.com/images/00/9911036M00-021.png
#252 (serpentine belt tensioner)
GM#12557838
$97.93 - list price
$69.78 - your price
http://www.genmotorinfo.com/images/00/9706116M00-023.png
#423 (oil pump)
GM#12555384
$329.27 - list price
$234.61 - your price
i have the serp. belt tensioner in stock but would have to order the other parts from GM
i have access to these same illustrations i just needed to know which ones you were talking about before getting specific
daveyhouse
09-25-12, 07:57 AM
Perfect,
need quote with shipping to 17404
for
GM#12581223 quantity 1
GM#12556030 quantity 2
GM#12557838 quantity 1
while we are at it, add a water pump belt tensioner to the list also. I understand having to wait for you to order parts.
The oil pump will wait for a couple weeks in another order.
RippyPartsDept
09-25-12, 09:40 AM
#12555153
$136.22 - list price
$97.04 - your price
(i have these in stock)
I'm wondering why you are looking to get an oil pump... they are usually not a problem at all.
Low oil pressure can be caused by an improperly torqued crank bolt or a faulty pressure switch can cause the light to come on when it shouldn't.
I have worked up a price quote for you. The total is $274.56 including UPS Ground shipping.
If you would like to order just give us a call and mention the price quote number (PQ2481) and we won't have to re-lookup any of these parts.
Cheers,
chris
daveyhouse
10-08-12, 11:04 AM
Chris,
I am ready for the oil pump price w/shipping.
P.S. Can you get the mounting bolts for the oil pump. Are these torque to yield bolts? I notice they are calling for an additional 35 degree turn for final pass.
Put them in the price if you can.
Thanks,
Dave
RippyPartsDept
10-08-12, 11:59 AM
I would assume that it is torque to yield due to that additional 35deg final pass but I'm not sure really. The guys in the shop said that off the top of their head that most of the bolts for these cars' engines are torque to yield but the only ones that really matter are the head bolts, the connecting rod bolts, and the crank bolt ... it's your choice i guess
also the bolts are sold in 5-pack bags so you'll have to buy two extra bolts just to get the three you need
oil pump
#12555384
bolts
#3538288
$2.10 - list price each
$1.31 - your price each
shipping will be $15 (with or without the bolts)
i've save a price quote for you when you call in that will make everything go smooth
if i'm not available when you call in just mention the price quote number PQ2521
cheers,
chris
daveyhouse
10-08-12, 01:56 PM
calling now, thank you sir
RippyPartsDept
10-08-12, 05:23 PM
i see you talked to my co-worker Duane.
looks like everything is all set
thanks for your business,
Chris
daveyhouse
01-12-13, 12:30 PM
Chris,
From above illustrations I need price and shipping to 17404
#138 / 2 please
#139
#140 / 2 please
#144
Also for the same 96 eldo y motor
Thermostat
Water pump belt
thermostat gasket?
RippyPartsDept
01-12-13, 01:24 PM
do you have the upgraded thermostat housing?
the original housing uses a smaller t/stat gasket
the upgraded housing began service after 2000 sometime (2002 year model maybe)
but it replaces/services all year model northstars
if you are doing a water pump it is suggested to upgrade the housing as well along with the new housing (teardrop) gasket and the thicker t/stat gasket
can you PM me your email address so I can email you a pdf of the price quote
daveyhouse
01-12-13, 04:30 PM
This is what came on the motor, its what we have currently have
EDIT TO ADD: Also I need 4 tubes of 12378521 sealant or whatever currently being used to seal the half case and oil pan.
http://i100.photobucket.com/albums/m6/daveyhouse/caddy/IMAG0060_zpsa8c15a53.jpg
http://i100.photobucket.com/albums/m6/daveyhouse/caddy/IMAG0062_zps1bed6455.jpg
RippyPartsDept
01-12-13, 09:52 PM
that's the original design
use permatex ultra grey for the sealant
http://drupal.caddyinfo.com/files/images/DSC02149.preview.JPG
the difference is subtle but the new design does not leak (the original tends to sometimes leak a bit)
daveyhouse
01-13-13, 11:22 AM
Guess we are upgrading that then.
While we are at it, we need a price for all the hoses before we put this engine in.
Rad, heater, etc. We want to replace all hoses for the cooling system.
This will be going into a 98 Deville D'Elegance.
Dave
RippyPartsDept
01-14-13, 09:31 AM
i thought you said it was a 1996 Eldo with a Y-motor .... are you working on two cars here or am i just confused?
can you make your full list of parts and for what vehicle so i can make sure we get everything you want on your price quote?
thanks
daveyhouse
01-14-13, 10:10 AM
This is a 96 Eldo Vin Y motor from a boneyard that I am rebuilding to put into a 98 Deville D'Elegance. Hope that helps sorry about about the confusion. I didn't know if there was any differences from motor to motor that is why I was asking for that year and model. But body wise I imagined theater hoses would be different on the Deville vs Eldo
#138 / 2 please
#139
#140 / 2 please
#144
Thermostat w/upgraded housing
Water pump belt
thermostat gasket?
all hoses for cooling system.
RippyPartsDept
01-14-13, 11:11 AM
gotcha ...
i'll be emailing you a price quote before lunch (if i don't get too busy)
daveyhouse
01-24-13, 04:13 PM
Parts received, thank you.
I will be in touch for the hoses at a later date.
RippyPartsDept
01-24-13, 05:03 PM
thanks for the order and the update
cheers!
:thumbsup:
daveyhouse
02-07-13, 10:39 AM
Chris,
Do you still have PQ2746 if so we need all of the hoses from that. You e-mailed me a copy on 1/14/2013. Also add a thermostat to that. We are ready for the next order
P.S. You have a PM
Sorry forgot to send the pm, it's there now
RippyPartsDept
02-07-13, 12:07 PM
It's no longer in the system... can you email it back to me? (along with your other additional requests to be added)
i'll make up a new PQ and send it back to you
daveyhouse
02-07-13, 02:45 PM
When I get back home I will email it back to you.
Gimme couple hours, I'm sure you will be off work by then.
Thank you
RippyPartsDept
02-07-13, 03:16 PM
no problem
daveyhouse
02-07-13, 07:08 PM
Okay I shot the quote back at you.
Need all the hoses off that quote and add a thermostat to that order.
P.S. I found that part, sorry to bother you with my negligence.
I thought it would have been in a bigger package than it was. LOL
Dave
RippyPartsDept
02-07-13, 07:24 PM
I was hoping you'd find it. Those types of mishaps do happen. (On my side too even)
I'll get on it for you in the morning and reply.
daveyhouse
02-08-13, 03:02 PM
Order placed
RippyPartsDept
02-08-13, 04:32 PM
cool... looks like you called when i was at lunch and spoke w/ the manager
all taken care of
daveyhouse
02-11-13, 10:25 AM
Chris,
96 Eldo Y motor
Serpentine Belt
8 flex plate bolts
4 torque converter bolts
and rear main seal
I imagine it the second design because it has hard inner and outer casing. Didn't the first design have a soft inner lip?
Also the timing cover numbers matched the 98 deville block, didn't know if that meant anything. Thought I remember reading something about that somewhere.
RippyPartsDept
02-11-13, 10:51 AM
i think you're right about that first design ...
the other way to tell is the width ... 9mm or 12mm (thicker is 2nd design)
the parts catalog also says that '96 models built before March 1996 will take the first design
belt
#19172679
$52.00 - list price
$32.50 - your price
flex plate bolts
#12561075
$1.94 - list price each
$1.21 - your price each
#11588468
$5.06 - list price each
$3.16 - your price each
rear main seal (2nd design)
#12568025
$51.62 - list price
$36.78 - your price
i've got them all in stock except the flex plate bolts
daveyhouse
02-11-13, 11:03 AM
Just went out and measured quick and got 11.77 so I guess we will call that 12mm
#19172679------ 1
#12561075------ 8
#11588468------ 4
#12568025------ 1
Lets do it
RippyPartsDept
02-11-13, 11:43 AM
Dave,
Saved you a price quote: PQ2836
give us a call when you get a chance.
daveyhouse
02-11-13, 12:33 PM
parts ordered,
Missed you again, I guess when you see my number you run out of the building, it's that PIA again, LOL
Thank you
RippyPartsDept
02-11-13, 01:52 PM
haha
well that's why i do the price quotes!
:sneaky:
daveyhouse
02-12-13, 11:00 AM
VIN 1G6KE54Y0WU702136 98 DEVILLE
Front motor mount please
RippyPartsDept
02-12-13, 03:54 PM
#22188025
$167.39 - list price
$119.25 - your price
shipping: $13
Total: $132.25
PQ2839
daveyhouse
02-13-13, 10:23 AM
#22188025
shipping: $13
Total: $132.25
PQ2839
Hey Chris can you throw a spark plug wire set on that quote?
RippyPartsDept
02-13-13, 10:39 AM
Sure
#19172245
$196.93 - list
$123.08 - yours
PQ updated
the wires are in stock but i'd have to order the mount
(will only take a day or two to get from GM)
daveyhouse
02-13-13, 05:17 PM
Hoses arrived,
Thank you
Also received bolts, belt, and seal.
I was puzzled because it came in a Amazon box. LOL
Thank you
daveyhouse
02-17-13, 03:43 PM
Hey Chris,
Do you a part number and price for these brackets that hold the coolant piping between the engine and firewall.
http://i100.photobucket.com/albums/m6/daveyhouse/caddy/100_4107bracketsneeded_zps926a8b06.jpg
Also part #513 from this image
http://i100.photobucket.com/albums/m6/daveyhouse/caddy/9804036M00-040_zps7a3e109d.png
I will probably have to add more as I go this week.
RippyPartsDept
02-17-13, 09:27 PM
is that the ECT sensor?
daveyhouse
02-17-13, 10:09 PM
It goes into the water jacket of the right head on the rear just above bellhousing. I'm guessing coolant temp. sensor.
2 prong connector
Doh!
ECT = Engine coolant temp.
the answer is yes to your ?
RippyPartsDept
02-18-13, 12:27 PM
yeah, now that I'm at work I can confirm that is the ECT
#15326386
$32.50 - list price
$20.31 - your price
I have one in stock
the brackets are shown in the catalog but don't have a parts listing
i called GM and they're a bit stumped by it
they're going to call me back in a while after looking into it a bit more
ok, so GM got back to me and found the clips/brackets
#25634923
$22.67 - list price each
$18.89 - your price each
they have been discontinued but VPI still has them
I can get them for you or you can order them directly from VPI ( http://vpartsinc.com ) but they'll charge the list price
either way is fine with me
just know that these parts from VPI are non-returnable (all sales final)
daveyhouse
02-23-13, 01:01 PM
Chris I am wanting to replace the steel water pipes that go into those clamps in the pic above in earlier post, but I cannot find them in any pics. Do you have a price and availability on those pipes?
RippyPartsDept
02-23-13, 01:57 PM
http://parts.nalleygmc.com/images/parts/gm/fullsize/0104046M08-010.JPG
#25688468
$60.62 - list price
$43.20 - your price
#25671310
$69.13 - list price
$49.26 - your price
gotta order them from GM
daveyhouse
02-23-13, 02:23 PM
Ok lets do it. One is bad might as well replace both.
P.S. Clamps and ECT problem has been taken care of
Got a PQ# for me?
RippyPartsDept
02-23-13, 07:34 PM
No PQ yet ... I can make one on Monday if you want.
daveyhouse
02-23-13, 07:38 PM
Monday sounds good. I am heading to Tn. Monday morning but my email will come through my cell so as soon as I get it I will call and place order.
Any idea how long it will take to get from gm?
RippyPartsDept
02-23-13, 07:41 PM
Not sure. Might only be a day if its in the Charlotte warehouse. There's a good chance that they have it. (I've got one in stock)
daveyhouse
02-25-13, 11:29 AM
Pq# yet?
RippyPartsDept
02-25-13, 05:06 PM
sorry dave... nice talking to you earlier
daveyhouse
03-02-13, 09:49 AM
Nice talking with you also Chris. Back from Tn Wednesday night and my pipes came Thursday.
Never thought a parts thread would go four pages.
Thanks you
RippyPartsDept
03-02-13, 10:23 AM
well you are doing quite the thorough re-build
it's kind of like taking a 'go big or go home' attitude to the repair
exciting to watch from afar
