View Full Version : 2008 sts front turn signal bulb
cyberhe
09-18-12, 03:53 PM
Can anyone tell me how to replace the front turn signal bulb on a 2008 STS?
curtc
09-18-12, 07:23 PM
Duplicate post.
Someone got impatient...
cyberhe
09-19-12, 01:40 PM
Curt: I followed your instructions and replaced the bulb easily.....Thanks!.....vinny p
jdub0012
10-01-12, 07:52 AM
I have a 2008 STS, the passenger side fog lamp has gone out, do you know how to access this bulb for replacement.
jdub0012
10-01-12, 10:24 AM
Curt can you help me out? i'm needing to replace the passenger side fog lamp on my 2008 STS.
curtc
10-01-12, 11:54 AM
Crank the wheel all the way over, remove wheel well liner. Now just get your hand back there and R&R the bulb...
Sure beats removing the entire bumper :thumbsup:
Ludacrisvp
10-01-12, 12:08 PM
Service manual agrees with you mostly ... the proper method to replace the fogs/signals is raise car, remove front wheel, pull the wheel well liner.
The bumper cover removal is only recommended / needed for the headlamps / peanut lamps.
jdub0012
10-01-12, 12:35 PM
Thanks for the help, sounds like I should be abl to handle that myself, dealer was wanting to charge $125, would you happen to know what type of bulb is needed?
Ludacrisvp
10-01-12, 01:17 PM
Lamp for DRL/Signal is probably 3157NA or 3357NA and the fog lamp is H3.
jdub0012
10-02-12, 09:55 AM
Worked great, I got the fog lamp installed in about 25mins.
