: Magnetic Ride F55
sub613
09-16-12, 08:53 PM
In 2006, I can't find the setting to change from touring to performance
on the suspension, I have the Nav, and there is not a setting for it.
Any help would be appreciated.
Thanks :cool2::cool2::cool2:
curtc
09-17-12, 12:26 AM
Go to the vehicle personalization, have to go down to see the option, also have be parked or moving at less than 3mph.
You're sure you have the F55 option?
1BadCadSTS
09-17-12, 09:49 AM
Or get the update that brings it right to the main screen so you can adjust in drive.
sub613
09-17-12, 11:13 AM
Yes, 1SF option 6, Sport suspension, Spoiler,Nav, 3.3 rear end,posi-traction,10 speakers,
Headlight washers.Wiper sensor.
dkozloski
09-17-12, 11:27 AM
I got the upgrade that moved that selection to the top. Before then I had to scroll down to the bottom of a list to change it. It was a PITA to find even when I knew where it was.
sub613
09-17-12, 02:36 PM
What IS the upgrade, is it the Nav disc ?
dkozloski
09-17-12, 05:00 PM
The upgrade is to the NAV firmware that must be done by a dealer service tech because it requires the use of a TECH2 tool. The TSB is #05-08-126-001B and covers voice recognition, personalization memory, and other stuff. The dealer will have to have Disc Set P/N 15943724. I was charged $90 by my dealer.
eatyoursandwich
09-17-12, 05:22 PM
Tech II. Dealer will flash upgrade it. $120 at my dealer.
sub613
09-17-12, 07:06 PM
Thanks Guys. Will do !
Ludacrisvp
09-17-12, 07:50 PM
On my 08 it's on the first screen when you press config and can be changed at any time / speed. I assume this update will do the same.
EChas3
09-17-12, 11:34 PM
2008 & up come with upgraded Nav.
Sub - My 2006 build sheet lists Magnetic Ride Control as RPO FE3. F55 is listed as CVRTD MAGNETO RHEOLOGICAL.
Crispy's build sheet is different (2008) but if you don't have the setting in config, you may not have the feature. If you have both F55 & FE3 on the label on your spare tire cover, keep hunting. It's gotta be there.
