View Full Version : Suspension Air pump Relay or Module Location
DCrooksy
09-04-03, 07:19 PM
1994 Sts. Can anyone tell me where the Air ride pump Relay or module is located, probably in the trunk behind the seat???
Katshot
09-04-03, 09:44 PM
Hell, I'm not sure. I could guess but that's not fair to you. I'll look it up in the a.m. and get back to you.
DCrooksy
09-04-03, 09:48 PM
Appreciate your help!
Katshot
09-05-03, 07:58 AM
OK, The compressor and exhaust solenoid are under the car together. The ELC relay is in the trunk in the #2 relay panel. The system is powered by (2) fuses, one (a 10amp) in the engine compartment fuse block and one (a 20amp) in the trunk fuse block.
DCrooksy
09-05-03, 10:02 PM
I put in a new relay & fuses are good. pump fires up ONLY when I jump 12 volts to it. info center reads Service Ride System & I cannot get the message out. I think it takes a scanner to remove message & then perhaps the system will activate. Any opinion would be appreciated.
