View Full Version : 2006 XLR Driver Door Issues
deodanth01
09-07-12, 04:40 PM
Hi guys,
New member here, I posted an intro in the appropriate forum, but I have a question regarding my XLR.
My car recently began to intermittently manifest a malfunction, which has become pretty much constant now. The car recognizes my Fob, and the passenger door opens fine, but the driver door will not open. I have to go through the passenger door and press the button to open the driver door. Occasionally, the inside button will stop working as well, and I have to use the lever. I have noticed that if I jiggle the driver door outside button, kind of an up/down thing with two fingers, it will occasionally release after a few tries. I figure that it may be the outside handle contacts or the like, however I have also noticed that I have to frequently re-index the driver door window as well.
I know from reading the past posts that there are several contributors that are actual techs or experts, and was hoping that someone might have an easy fix for this problem, as my warranty period has lapsed and we all know how expensive these beauties are to diagnose and repair.
Thanks!
~Rick
XFireXLR
10-01-12, 12:32 PM
If you haven't already found a solution to your issue, it may just be your battery. Our cars doing weird things when the battery starts losing voltage.
:cool:
deodanth01
10-15-12, 07:10 PM
Does anyone have the part number to the driver door handle? The rubber booted button deal, because I'm fairly sure it's the problem. Thanks!!
hawkeye372
12-27-12, 08:12 PM
Hi guys,
Thanks!
~Rick
Mine has just started doing this. I just replaced the batteries in both fobs hoping that might do the trick. Um. I will keep monitoring this and thanks for sharing. Ill keep the battery info in my mind. I guess the next issue is having the dealer do a battery check.
Cadillac Cust Svc
12-29-12, 05:46 PM
Any news, hawkeye372? If you decided to get anything checked into by a dealership, please be sure to keep us updated.
Sarah (Assisting Katie), Cadillac Customer Service
ccclarke
01-05-13, 11:57 AM
The driver's door switch P/N is 751230. It's less than $10 at gmpartsdirect.com.
CC
