: Nav squeaks when it's hot out.
GAGS-V2
08-31-12, 10:40 PM
When it's hot out and the nav system rises up from the dash, mine squeaks. It does it when it goes back down too. Only when it's real hot out. Anybody else have this going on?
cruiser68
08-31-12, 11:38 PM
Same here. Only when the car is closed up and in the sun.
larry arizona
09-01-12, 08:36 AM
+2...... does not bother me. I would squeak too I had to work in 150F temps......
V locity
09-01-12, 11:57 AM
+3...
thavil
09-01-12, 12:03 PM
There is a TSB for the NAV squeak. Had mine fixed last month by the dealer. They have to access the gears and put different lube than what they used during the build.
F U FAST
09-01-12, 06:58 PM
Same here. Dealer is going to take a look at it when I get time to get it down there....
muohio
09-01-12, 10:12 PM
Mine does that also along with a lot of rattles and creaking until the interior cools off.
simgolfer
09-01-12, 10:14 PM
Car has creaks like trees in a forest. When the sounds start to bother me, I drown them out with some wot and all is right with the world again.
larry arizona
09-01-12, 10:30 PM
not taking my V into the dealer to fix a nav squeak. 1/4 tank of gas, 2/32nds of tire and 100 miles later NOPE
tedcmiller
09-02-12, 04:58 PM
My 2009 CTS-V does not squeak. But then it rarely gets to 100 degrees F here. Also, I keep the car is a shady garage most of the time.
mrkool
09-02-12, 08:43 PM
a long time ago i learned to turn up the music and not worry about these squeaks on my other cars :)
WGT31
09-02-12, 10:18 PM
+ 12
Cadillac Cust Svc
09-04-12, 12:58 PM
I'm so sorry to hear about all the squeaking concerns! I have documented this thread's URL where various GM departments can access it. If any of you would like me to contact your dealer to follow-up on your concerns, then please contact me for further assistance. I'm available via direct message anytime or via email at Katie_Lucille@gmexpert.com.
Best,
Katie
Cadillac Customer Service
cdog533
09-04-12, 01:29 PM
+1 if left in hot, direct sun.
I would not take it in for this, as pulling it and regreasing it is more likely to mess it up that keeping the miniscule squeak in place.
jft69z
09-04-12, 03:37 PM
+15, mine squeaks too, but not bad enough to have them mangle everything else around it.
larry arizona
09-04-12, 05:06 PM
AMEN. It is so minor.
larry arizona
09-04-12, 05:07 PM
The tires squeal and smoke badly when I mash the throttle too, can the dealer fix that?.............:yup:
McGuffy
09-04-12, 05:15 PM
I love that Cadillac reps monitor and respond to issues on here. That's how you (re)build a brand :)
larry arizona
09-04-12, 07:44 PM
Used to have the lead engineer of the V respond on here until he got attacked by some on the forum. GM Engineers do read these forums regularly. They do care and they do listen. Just treat them with respect, they are busy and already overworked. This is a brotherhood/fraternity. We should treat each other as such.......
khoeysr
09-11-12, 11:08 AM
Mine does that occasionally. It's not a big deal for me. I would have to think there is something that could be applied to the side of the riser to eliminate the squeak for those who can't take it.
