View Full Version : So why do you think my heated seats fail to work?
BeelzeBob
09-04-03, 08:22 AM
Okay. I turn them on and get the 'telltale' light saying they're on - but the seats don't heat up. What are the likely possibilities.. I'd like to make this an easy-to-find discussion when people do a search...
Thanks in advance...
toomanytoyz
09-04-03, 08:46 AM
Well, it's only 4 nuts to remove the seats... Maybe you can see if it's just as simple as they are unplugged? :confused:
BeelzeBob
09-04-03, 09:32 AM
Could they be unplugged? Would the light still go on if it's not plugged into the actual seat? I'm figuring Yes but I thought I'd ask.. It just seems like low-mileage for both seats to not be working.. So you may be right..
toomanytoyz
09-04-03, 09:35 AM
Well... My reasoning was this... It was a southern car. Probably didn't EVER use them. So maybe they were unplugged so as not to accidentally use them?
Them old people do wierd things... :D
BeelzeBob
09-04-03, 09:44 AM
Good point... I'll definitely check this out as soon as I can. Hopefully this weekend.. There's no way to check this without removing the seats though. Right? That would be so nice. :D
toomanytoyz
09-04-03, 10:20 AM
Well, you could try moving the seat all the way forward and all the way up. You may be able to go in from the back seat and look up...
BeelzeBob
09-04-03, 10:42 AM
Well I'll certainly try that first then.. It would be so nice if it was this easy to fix.. Just plug it in. :)
Katshot
09-04-03, 12:25 PM
Sal,
The seat heaters both work off the same (2) fuses. #17 (10amp) and #40 (15amp) in the I/P fuse box. If the 10amp is good but the 15amp is NOT, the LED indicator WILL light but the seats will NOT heat up. The 15amp fuse supplies the power for the seat heater module located under each seat (they're basically the thermostats for the seat heaters). I would start by checking BOTH fuses, then check under the seats for bad connections. I will assume the ground is good because both seats share the same ground and since the LED comes on, that should indicate that the ground is good.
BeelzeBob
09-04-03, 12:37 PM
Thanks for the info.. Where's the fusebox? I'm gonna go check this in a few minutes...
toomanytoyz
09-04-03, 12:44 PM
Open driver's door... Look at side of dash. There it is! :)
BeelzeBob
09-04-03, 12:48 PM
Thank you! :D Here I go...
BeelzeBob
09-04-03, 01:02 PM
Okay, I'm not THAT lucky today.. The fuses are fine.. I took a quick look beneath the seat and didn't see anything hanging, unplugged.. I'm guessing it'll be a more complicated fix...
davesdeville
09-04-03, 06:29 PM
You should first detemine if you really want to spend your time and money on fixing something like a heated seat..
2dfx
09-04-03, 06:48 PM
Sal I guarantee you its the seat pads. Theres a element mesh that heats up when the switch is on and its prolly worn out.
I was quoted $700 CDN to fix it (unstitch, replace element, restitch new seat with new leather)
BeelzeBob
09-04-03, 07:18 PM
$700 Canadian.. Does that mean about $350 here? Or $1400? I forget...
The only reason I feel it's unlikely that they're worn out is that the car only has 60k and it's lived down South all its life. Florida... Heated seats worn out? Ya know?
2dfx
09-04-03, 07:29 PM
More like 500.
Sal, all it takes is someone to sit on the seat with keys or a lot of change in their back pocket to put pressure on the thin element ot break it!
toomanytoyz
09-04-03, 08:47 PM
You are sitting in the seat when you turn them on, right? Mine don't seem to come on unless someone is sitting on them, and even them they take a good 5 minutes to warm up....
BeelzeBob
09-04-03, 08:57 PM
5 minutes to come on? It look my ETC like 20 seconds to start getting warm... Otherwise.. I guess both seats could have been sat in heavily and broken.. Would that be $500.00 for BOTH seats? Or each? And this includes new leather?
Katshot
09-04-03, 09:24 PM
Sal,
It's not the pads. At least the chances are astronomical. There's (4) pads and you're gonna tell me that ALL 4 are bad? Probably not. You have 4 pads, 2 modules, and 1 switch, now think REAL hard. I'm sure a little troubleshooting can uncover the problem. I'll email you the schematic.
BeelzeBob
09-05-03, 10:24 AM
It actually felt like MY seat came on a TINY, TINY little bit last night on the way home. Tonight, I'll have my girlfriend turn her seat on and leave it on - and see what happens.. My ETC seats got very noticably hot..
toomanytoyz
09-05-03, 10:37 AM
Even when mine get hot, they don't get that hot... It won't go through a jacket in the winter, but you'll feel it through jeans...
Wimpy heaters... :(
2dfx
09-05-03, 10:37 AM
Whatever gives you a hot ass! :histeric:
BeelzeBob
09-08-03, 10:02 AM
Just an FYI.. I've been using my heated seats every day and they're beginning to work. Well, I only sit in the driver's seat so I know that one is beginning to work. Is that odd or what?
toomanytoyz
09-08-03, 10:51 AM
They had probly never been used before. :)
And why the hell are you using them now??? It's still warm out?!?!? :D
the Sandman
09-08-03, 11:24 AM
And why the hell are you using them now??? It's still warm out?!?!? :DIf the Webmaster of the CadillacForums wants his ass warmed who are we to question it?? :D
BeelzeBob
09-08-03, 12:12 PM
Hahaha. I was just HOPING to have them come on one day - and they did.. Maybe they really were never used before..
elwesso
09-08-03, 05:41 PM
That had to get "warmed up" for maximum performance....... :histeric:
BeelzeBob
09-22-03, 07:39 AM
Passenger seat verified - working. :D It was a bit cold last night so I asked my girlfriend to test it out - and it works.. I'm glad. :)
gabeval
10-15-04, 04:26 PM
Did you ever figure out the cause of the problem?
I'm having the same problem in my 2000 DTS. Some times the two front seats get slighty warm, sometimes not at all, but they're never not as hot as they used to.
Thanks.
