: 2011 CTS-V Transmission Leak
08-23-12, 09:21 AM
Took my V to the drag strip last night and after the 6th run (2nd round eliminations pass) I heard over the loud speaker that I had "left something at the line." I stopped at the top end after getting my slip and noticed a small pool of ATF under the car. It seams to be coming from he rear of the transmission (auto). I will lift the car up tonight and try and see exactly where it is coming from.
Any known/ common leaking issues?
V locity
08-23-12, 09:33 AM
Sounds like you blew the seal? If that's the case (no pun intended), its an easy fix... Should be warrantied too.
