View Full Version : 1998 Eldorado all parts except heads and block (Black on Black)
08-20-12, 12:29 AM
The car is black on black with perfect seats front and back left and right the only interior not good is the master window switch for both windows there is a small dent in the hood right near the crease about a foot in from the front edge and the passenger fender has slight damage both dents are easy fix the tail lights have some heat cracking on the top if looking down from the sky but from the rear look perfect over all the other exterior parts are good. The motor has been overheated replaced head gasket and milled heads not the block and then same problem head gasket or heads or block mating surfaces and therefore not for sale but pistions cams gears compressor alternator ect. ect. ect. All for sale and priced to move asap I am in Florida and will meet you half way in this state or ship to you for cost of. I can remove any part needed or take the whole car less motor and Rims I can send photos if needed from my phone and will take as many as you need Call Andy 772-528-6271
