czwsecurity
12-09-04, 04:13 AM
Hello folks
I had my 97 deville at the dealer last week for the fuel rail recall and some fluid changes. Also had the egr valve replaced. Ever since Ive gotten a p0300 misfire code and a blinking check engine light when on the throttle. When under the hood with the car running, I saw arcing inbetween the 2 points on the far left coil 7/8. Is this the coil failing or the plug wires??? Its obvious some thing was disturbed during the fuel rail replacement as these symptoms were not present beforehand. (only documented code was p0404 (egr was dead, couldnt even clean it) I was also wondering if this was safe to drive back to the dealer the way is is (about 15 miles). They are expecting the car back friday.
failing coil or wires???????
By the way they even snapped my cruise control cable during the fuel rail recall also, but at least they were up front about it and will replace friday also...
thanx folks, I have have learned so much her in just a month I actually feel comfortable popping the hood now LOL :worship:
