: 2005 sts oil level sensor
Dvargas2811
08-10-12, 06:35 PM
When is the check oil level light supposed to come on in the vehicle. I know that it has a sensor for oil level, when should it come on?
dkozloski
08-10-12, 06:49 PM
It comes on just about the time the connecting rods let go.
Kingoftypos
08-10-12, 07:26 PM
:yeah:
How do you figure there is an oil level sensor? If you are thinking the OLM has a level sensor, you are sorely wrong. OLM stands for Oil Life Monitor.
KOT
JimmyH
08-10-12, 08:13 PM
moved from cust svc.
lulz koz :lol:
curtc
08-10-12, 08:38 PM
My 2001 Seville had one, came on at about 2 qts. low if I remember correctly.
Not sure if the STS has one. I'm almost 2k into my oil change and haven't used a drop.
EChas3
08-10-12, 11:13 PM
Koz is right; one of the few oversights in this car.
curtc
08-11-12, 04:20 AM
So no oil LEVEL sensor in the N*? I know the 3.6 doesn't have one...
mckellyb
08-11-12, 01:01 PM
There is an oil level sensor...it's called a dipstick.
KRSTS
08-11-12, 01:09 PM
Which I believe the manual suggests you check at every fillup:thumbsup::thumbsup:
RippyPartsDept
08-11-12, 01:11 PM
V8 northstar engines have a level sensor ... V6 engines do not
1BadCadSTS
08-11-12, 01:15 PM
It ain't that great then. I got used to not having to check as previous northstars went off when a qrt low. My STS4 was 3 qrts low yesterday and no light.
mckellyb
08-11-12, 01:25 PM
I'll admit, I don't check weekly, but rather about every 3K miles, because the N* uses about half a quart of M1 goodness over the OLM's 100% life.
OLM gives me 'bout 12K-13K miles. I'm quite happy with this, because I've used "extended" oil change intervals while using Mobil 1, since around 1992.
EChas3
08-11-12, 11:19 PM
No, I'm simply agreeing with Koz that Cadillac erred by setting the N* low oil warning far too low.
I am surprised to learn they neglected to include even a poor sensor in the V6 models, since they need it even more.
Ludacrisvp
08-11-12, 11:42 PM
I've gone about 6k miles on this oil change. OLM shows 65% checked dipstick and doesn't appear to be using any still at about 3/4 - 7/8 on the dipstick. This is 08 N*. My 02 N* was at 1qt per 1500-2k miles.
dkozloski
08-11-12, 11:44 PM
I've seen reports that at least early CTSs with a 3.6L V6 have an oil level sensor but it only triggers if the oil level is low at startup. If it knocks a hole in the pan while driving you're SOL.
C&C
08-12-12, 05:28 AM
Not too little but too late (for some); GM has added oil level sensors to the 2013 3.6L and 3.0L engines.
