View Full Version : Where is the fuel filter on a 90 Coupe DeVille??
Dragonshield
09-02-03, 11:34 PM
I have a 1990 Coupe Deville which just started to stall. Today it will not start. I have noticed a loss of power, like it was starving for fuel when trying to go up hills. I took off the aircleaner and tried to start the engine, pumped the gas pedal and should smell gas. I don't. My guess is either the fuel filter or fuel pump. When I just turn on the engine with the key I do hear what I belive to be the fuel pump.
I want to start with the simple fix, the filer. Can anyone tell me where they stashed the fuel fileter on this car?/
Thanks
elwesso
09-03-03, 07:47 PM
Welcome....... Thanks for signing up :wave:
Im not sure exactly where it is, but if I recall correctly some other modern cadillacs have the fuel filter under the car.... Not sure.......
And, if Im not mistaken, you wont smell gas because this isnt a carburated engine.......
davesdeville
09-03-03, 11:10 PM
Wes is right, it's fuel injected. I don't know where the filter is, maybe if you go buy a replacement at a parts store, the person there could probably tell you.
vanaisa
09-04-03, 02:33 PM
There are two places, where fuel filter can be: under the car near fuel tank or under the car near transmission, in left side...
Its really easy to replace too
elwesso
09-05-03, 05:20 PM
Will you need to jack up the car to get to it, or can you just lay on the ground to get it.....?
Katshot
09-05-03, 05:33 PM
If memory serves, it's on the right side right around the area of the R/R seat outboard side. The Fleetwoods are to the inside of the frame rail on the opposite side (left side) of the car. It's a metal, in-line filter.
