: Headlights
NYS Kurt Bush
07-13-12, 05:04 PM
Anyone have any headlight issue. My driverside headlight is dark blue and flickers on and off.......? Is it the bulb or the balice?
Skidmarcx
07-13-12, 07:17 PM
Could be either... Not sure how hard it is to replace bulbs, but you could swap sides to narrow it down
JDB
07-13-12, 08:00 PM
Swap bulbs, see if it follows. If not, ballast.
NYS Kurt Bush
07-16-12, 09:43 AM
Is their any cheap way to fix the headlights or cheap place to get parts. Or should i just bite the bullet and do it at dealer price??????
FuzzyLogic
07-16-12, 11:42 AM
I think the real question is, if you can't afford a $150 set of replacement D1S bulbs and the 40 minutes it takes to replace them, what other required maintenance are you neglecting?
NYS Kurt Bush
07-17-12, 08:16 AM
Where did you find the bulb for that price? Cheapest i found was 275?
NYS Kurt Bush
07-17-12, 08:17 AM
If it is the bulb and not the balace........
rand49er
07-17-12, 08:36 AM
It's "ballast."
Cadillac Cust Svc
07-17-12, 11:55 AM
If you've never checked into gmpartsdirect.com (in the event that it turns out to be a bigger problem than a bulb replacement and you needed a place to find parts), you may find some good deals there.
Let us know if we can check into anything for you,
Sarah (Assisting Katie)
Cadillac Customer Service
Bigtuna819
07-17-12, 04:23 PM
i ordered d1s from ebay for $30... had them in for 8months now, no complaints
ctsvohio
07-17-12, 07:00 PM
I ordered 2 from eBay for less than $50 and went ahead and replaced both. No problems with them.
GDPossehl
07-18-12, 12:51 AM
... that is if you don't mind waiting two weeks for parts.
WickedIXMR
07-20-12, 02:25 AM
Let us know if you find out what the problem is. I have this same issue. Seems like it happens more when there's more vibration. IE. braking hard or accelerating hard from 1st to 2nd gear. Haven't had a chance to diagnose the issue since I just bought the car today.
