View Full Version : Euro Nav Disk for 2004 XLR
Kenno
07-13-12, 03:37 PM
Hi All, I'm trying to help out a friend who has a 2004 XLR in Europe and needs a Euro Nav Disc if it will work. I've read many conflicting stories thus far on the web. One thread I found on this site said that the Nav Unit changed in 2008. I have been on the GM Nav Disc site and I have discovered that the only year they list a Euro Disc for is the 2009 XLR. For all other years from 2004 to 2008 they only list the North American Disc as available. So my questions are:
1) Is there a hack that will allow the 2004 Nav Unit to read the 2009 EURO Disc successfully without causing problems with the radio, etc?
2) If not is the only other solution to replace Nav Unit with the 2009 Unit? If so what is the price and model number of the Nav Unit?
3) is there a difference between the Euro and the American Nav unit? He only uses FM radio.
Thanks very much! What a beautiful car!
ccclarke
07-14-12, 11:52 AM
1) No hacks listed for Euro Nav conversions- 2004-205 Denso Infotainment units can be hacked, but it takes lots of time and patience to do so. No guarantee it would yield results anyway.
Your options are limited:
2) Buy the GM NAV disk and see if it works. That's cheaper than buying a new head unit. (Less risky than buying the head unit first.)
3) If it doesn't work, buy and have a dealer program the 2009 head unit. (Outrageously expensive for the antiquated technology you get, but totally compatible with the vehicle's low speed data bus.)
4) Install an aftermarket head unit. There will probably be some loss in functionality of the control switches on the steering wheel and possibly the HUD. (Good luck with this approach.)
5) If all he uses is the FM radio, why bother with the $200 nav disk and/or more expensive head unit anyway? Just use an aftermarket standalone NAV system. They can be had for less than the price of a nav disk, are easier to update and portable between vehicles. (The common sense approach.)
CCC
Kenno
07-15-12, 05:33 AM
Thanks for the advice. I agree the stand alone GPS is the easy solution. It's simply a question of wanting to keep the cockpit clean if possible. I'm amazed they made it so complicated to upgrade. I've never run into a problem like this with my Garmin's
Kenno
07-16-12, 05:59 PM
One further question: Will the 2009 USA Nav Unit for the XLR work for sure with the 2009 Euro Nav Disc without further modification? Does anyone know the part number for the 2009 Nav Unit and how much it costs?
Thanks!
ccclarke
07-16-12, 11:58 PM
The 2006-2009 head units list for $3846.38. Discounted through gmpartsdirect, they're $2400. You can see why upgrading to a newer head unit is a case study in the laws of diminishing returns, --even at the discounted price. Export models may be different, so if that's what your friend wants, have him contact a European GM dealer for compatibility and let them take the risk ordering/installing something that may or may not work out.
As for disk compatibility, you need to contact GM. Your chances of finding an owner that has gone this route and posts online are marginal at best.
CCC
