View Full Version : peanut light replacement?
STS-4000
07-06-12, 10:06 PM
Hello my fellow Cadillac friends, I Just wanted to know if there is an easy way to replace that little peanut light in the bottom corner of the headlight assembly.
I really would appreciate any feedback on this guys, Thanks.
curtc
07-06-12, 11:16 PM
You either have to remove the bumper our remove the intake and fuse box to get to them from the rear
STS-4000
07-07-12, 01:47 AM
Thanks bud, I'll try removing the fuse box and intake in the morning.
Thanks again.
STS-4000
07-07-12, 11:17 AM
Okay last question. I pulled the intake out and now I'm looking at the backside of the headlight assembly. Now, are the peanut lights located behind the grey plastic cover where my hi/lo beams are or are they located somewhere else?
curtc
07-07-12, 01:48 PM
Should be an access door you need to remove on the inner side of the headlight assembly
STS-4000
07-07-12, 03:23 PM
On the inner side? So does that mean I still have to remove the grey plastic cover to get to the bulb? If So, which plastic cover do I need to remove because I see two. One on the back and one the side of the headlight assembly.
aliskerov
07-08-12, 11:59 PM
remove the onw on the side. You'll see a thin set of wires running to the peanut light location. The bulb holder "turns" out of it's location - try to spin it with your fingers. Hope this helps - i got to do mine on the passanger side. Still have no idea how hard moving the fuse box is....
STS-4000
07-09-12, 09:58 AM
Ah okay. I always thought the grey plastic cover on the side of the headlight assembly is where the ballast was located.
Thanks Man.
curtc
07-09-12, 08:30 PM
I believe the ballast is located at the bottom of the headlight assembly.
aliskerov
07-09-12, 08:33 PM
Hard to remember. It might be, but I know for a fact that the quickest route to the peanut light is through the side one
STS-4000
07-10-12, 11:15 AM
okay i found the bulb and it was pain in the @ss to take out. turns out that my new 9 smd led's didn't fit because it was too long, so i'm gonna order 5 smd led's instead and i'm pretty sure they'll fit just fine.
GreyFox
01-19-15, 04:13 PM
So, did the 5 smd led bulbs fit?
