: '68 de ville starter/electrical SNAFU
07-06-12, 05:27 PM
I replaced the bulbs in the rear reading lights
'engine temp' light came on - and has remained on ever since
[whether the key is in the ign or not].
battery went completely dead after that
I replaced it with a good used truck battery {have kept it unhooked}
15-20 attempts at starting - none have worked
despite testing and recharging the battery [after sitting for a few weeks at a time
so ... I took it to a mechanic [who kept it for 2 weeks] -
he told me it was a bad connection at the alternator.. I drove it home
the engine temp light came on 3 days later and it's been downhill ever since so to speak...
anything anyone's got will be more than I have,. thanks!!
07-06-12, 11:17 PM
I would check the voltage regulator. One of the points inside could be sticking, causing a back feed, even with the key in the off position. Tap on it with the butt of a screwdriver and see if the light goes out. I am thinking the engine temp. is actually your alternator light. If the engine temp light is on, usually a warning buzzer comes on too (past experience). Maybe the two warning lights got crossed somewhere along the way.
