: 08 sts door panel removal?
Loadtoad101
07-06-12, 02:25 PM
08 STS, having trouble getting drivers door panel off. I have removed the one screw behind the door latch and popped all 7 retaining pins around the door. The door panel is still attached in the area where the rear of the arm rest is. It is attached solid to something. The alldata repair manual diagram shows two screws that go thru the arm rest handle area but there is no access to this area via a removable panel. Anyone removed this panel? If so what is the remaining item I need to do to get the panel off?
Reason for door panel removal is to repair the arm rest where one's elbow sits. Previous owner caved it in with his elbow somehow and I need to see If I can repair it. Thank you.
1BadCadSTS
07-06-12, 03:04 PM
Because there are two screws behind the arm pull. Pull up the leather that goes into the "cup" of the arm pull.
Loadtoad101
07-06-12, 09:04 PM
Thank you BadCad. I pried up on the leather at that location and a small flap hinged upward enough so I could get to the screws. The door fell off at that time. Found that the previous owner had broken all the plastic supports that hold up the area where one's elbow rests. Same owner that broke both sun visor mirror doors, broke the shift assembly, broke both passenger and driver side seat side plastic trim pieces. Guy was hard on his car.
Ludacrisvp
07-06-12, 09:31 PM
eBay has some full door panels in a few color choices for the 08 STS that you may want to check out.
Loadtoad101
07-07-12, 04:09 PM
Got the panel repaired and looks almost like new. Only flaw is the leather is not completely taunt at the elbow area like new but is acceptable.
Amigobear718
02-16-15, 11:19 AM
I got a question? do the courtesy lights come on at night only? Just installed ghost lights in the day time but can't get the courtesy like to come on....
framedforlife
02-16-15, 11:21 AM
Yes only at night.
Amigobear718
02-16-15, 11:45 AM
Yes only at night.
Hey man thx Can't wait to see if there upside down lol.
Ludacrisvp
02-16-15, 01:08 PM
Just cover the sensor on the dash to make the car think it's night and it will make the door lights come on.
Amigobear718
02-16-15, 04:46 PM
Ill give it a try
Thx a lot that worked perfectly
sub613
02-16-15, 08:22 PM
Amigobear 718, Any Pics ? Night Pics Preffered.
Was thinking of these, For My STS.
Happy Motoring. :welcome::cool2::cool2:
Ludacrisvp
02-16-15, 08:52 PM
What are ghost lights
Amigobear718
02-16-15, 09:15 PM
Here you guys thx for the help.
http://i60.tinypic.com/x21gna.jpg
Ludacrisvp
02-16-15, 09:27 PM
Ah those. I too have them on all 4 doors.
sub613
02-16-15, 09:32 PM
Briefly, you have to drill holes in the bottom of the doors, to mount them,
and tap into the existing door lamps, for power !
Is that pretty much it !
Happy Motoring.
Amigo, thanks for the pics
Jrx4dad
04-23-15, 11:10 PM
I just got a set with no wiring instructions. What wire did you splice into?
Ludacrisvp
04-23-15, 11:45 PM
I used the wires that run the door lamps that light up the ground outside the car when the door is open.
Pretty simple to do.
daddy_o
04-24-15, 07:13 PM
I plan on installing these soon myself. Should the window be up or down? Should the power be disconected? Im also putting on a new pass. side mirror, entire assy, any tips anyone?
Jrx4dad
04-26-15, 01:25 PM
I don't think the window position matters, you're working in the door panel. It removes easily.
