View Full Version : The Caddy has its very own garage
N*Caddy
07-03-12, 12:03 AM
Is been over a month now since the Cadillac has its very own garage.
http://img406.imageshack.us/img406/8714/garagef.jpg
First thing I did was fix the driveway, then paint it.
Then I started retooling it. I already did my first (unnecessary) repair, replaced the not so good loocking power steering cooler with a mint unit. Took me a whole half-hour to do it, once was done…now what I do next. Basically I am hoping to have an issue to fix. :D (I know is/I am weird).
I did a fuel line swap (to steel) on my friend’s Eldorado and a tune up (finally he passed emissions) and that’s because I ran out of projects on my car. Well there is plenty of lawn to keep me busy but although sometimes involves an engine, is just 1 cyl 198cc, no fun. I guess I would like to build one day a V8 lawnmower. :cookoo:
In anticipation to the complete brake and fuel lines replacement job I am planing this summer I already purchased the fuel line disconnect tool and a 3-ton professional floor jack (I mean is the one a mechanic shop will use). I think I overbought for my needs but I always wanted a big a$$ floor jack. Obviously I have the jack stands to match and next is a creeper. I need to get a good quality brake line flare tool. A friend offered to loan his even without me asking but I want my own.
I got prepared for the first oil change in my own garage (I have everything I need) but I am still 1000 miles from it…damn can’t wait.
And you can’t call it a garage without good car wash equipment, that would be the mop pail I drove 40 miles to buy it, I always wanted this exact pail (professional grade, very strong built) not the $18.99 Home Depot special.
http://img716.imageshack.us/img716/4074/carwashw.jpg
My vacation for this year will be finishing the garage (drywall + epoxy on the floor). Then I want to find a legal specs STOP sign and hang it right on the bottom wall.
After that I want a license plate from every state in the epic trip.
Still looking for an at least 20 gal. air compressor, a tool box, full set of tools (air and regular)…oh boy the fun I have.
vincentm
07-03-12, 12:25 AM
Very nice congrats man :-)
talismandave
07-03-12, 12:52 AM
I already did my first (unnecessary) repair, replaced the not so good looking power steering cooler with a mint unit. Took me a whole half-hour to do it, once was done…now what I do next. Basically I am hoping to have an issue to fix. :D (I know is/I am weird).
I did a fuel line swap (to steel) on my friend’s Eldorado and a tune up and that’s because I ran out of projects on my car.
I already purchased the fuel line disconnect tool and a 3-ton professional floor jack (I mean is the one a mechanic shop will use). I think I overbought for my needs...
First of all, good on you for the garage! Sounds great, I'm trying to do work in an apt. parking lot!:duh:
Second, doing unnecessary work, hoping to find a problem to fix, and working on friend's car's.....have I got a 74 Cadillac for you!
Hi!:wave:....I'm Dave....want to be friends?:D
Third, not possible to overbuy for your needs. Just can't be done. Period.
Lastly, friends loaning tools is always nice. However, at you age, if funds aren't a problem, always buy.
Take good care of them, keep them organized, and they will be there for life. I live in an apt. now, but I still have my roller chest in my walk-in closet.:cookoo:
About half of the tools in there are my dad's from before I was born, or mine from my first car in 1975. They are without question, among my most highly prized belongings. (Also coming in handier than I ever thought they would when I moved them in there!)
At 53, with a car under warranty, I thought my wrenching days were over. Then that damn Ebay changed all that.:noidea:
That is why you can never over buy for your needs. You never know what your needs will be.
CadillacLuke24
07-03-12, 02:01 AM
You are my new hero. Just sayin' :D
Excellent job on the garage! It sounds finally worthy of the beauty you plan to house there and work on :thumbsup:
No, you can never overbuy. NEVER EVER EVER. You're just especially prepared :yup:
Congratulations on the FINE Cadillac, and have fun with your projects (whenever they may come)!
N*Caddy
11-18-12, 11:41 PM
I spent most of this year's vacation working in the garage (in it and on it).
I frame it, drywall it and paint it. This involved building an attic for storage, my garage will have 0 items along the walls or hanging on the walls, everything is out of side in the attic (or shed - for large items). I also redid all the electrics (new wires, plugs, junction boxes - the works).
Unfortunately the amount of time from my vacation I allocated to this task (1 week) was not enough - I was just working by myself, so I had to take a couple of days off after, plus about 3-4 weekends (including a long weekend).
But as is now (other than some of the tools and old junk still along the walls) the walls are done and painted (most will consider the garage complete). Ceiling is white (flat) and the walls are medium gray (semi-glossy).
I am still planning to put trims for the back door, and the attic access hatch. The hatch is positioned between the garage door rails. The reason for that is when the garage door is opened it covers the access hatch.
Now the crazy ($$) plan is to run along all the wall corners (including along the bottom) 1’x1’ stainless steel 90* trim made to look like is riveted giving the illusion is what’s holding the walls together (kind of like old fashion bridge construction). I am looking for a cheap supplier for the corner pieces (I need little over 140 feet of it).
Still with the walls/floor, now the floor is unfinished concrete, I was looking for doing dark marble finish using UCoat It Epoxy with the flake finish and clear coat on top. I am also planing to embed underneath the clear coat a yellow/black line 1 foot away from the edges (in a “////” pattern). That has to be next year as now is too cold for that.
Back to the electrics…I wanted to tie the exterior lights (the fixtures on each side of the garage door) with the garage door opener timer (you know that light on the garage door opener). Well I didn’t just tied the lights to the relay, I made a light sensor (I designed/made the PCB myself using a couple of NPN transistors, 3 relays and few other components). I modified the garage door mother board to get a signal when the timer is ON, I use this signal to turn on a small relay that powers the light sensor board, the light sensor (LDR) I mouthed in one of the 2 fixtures. I actually bought one of those LED night lights just to get the small plastic lens to cover the hole I drilled for the LDR in the fixture body (is a very small hole and looks like is factory made with the nice lens on.
There are low voltage wires running underneath the drywall from the garage door opener to the light sensor controller and then from the controller to the LDR outside in the fixture. The light sensor powers directly from 110 AC but I made a transformless power supply to a safer 15V DC level using some ceramic capacitor, a regular diode, a Zener Diode and a resistor. Then all these are the light sensor controllers mounted in a project box and hidden in a junction box in the walls (is masked with the garage light switches. Obviously the controller is override with the manual switch (if needed).
Man I should really made some pictures…
The result is:
During the day when is light outside if I open the garage door only the light on the garage door opener itself turns on, the exterior lights are kept OFF by the light sensor board.
When is dark outside opening the garage door will also turn on the exterior lights and will remain ON until the garage door opener timer expires (~3 min).
This solves 2 problems, first I don’t turn the exterior lights unnecessarily during the day and 2, when I hit the home link button at night (coming home) to drive the car in the garage, I have lights outside.
Picture this: you approach the garage door opening with headlamps on, all is fine as you can clearly see where is the car in respect with the door frame. But in the moment the front of the car passes the doorframe pitch-dark outside, you can’t see how far are your mirrors from the doorframe (sure you can wait 10 seconds or so and the eyes will adapt but…you see the inconvenience).
Next electrical project is get a small computer (something like ITX format) and mount it above the garage door opener bracket (man I built a super nice and sturdy bracket – took me a day, I can call it a designer bracket). This will be a web server and I am planing to write a small software (web page or webservice) to override the lights and the garage door switch, also link it with the garage door position sensor (open close) so I can control the door and the lights over the internet.
Yeah I will get some pictures when I get some time, maybe a small movie with how the exterior lights turn on from the Homelink button in the car.
CadillacLuke24
11-19-12, 12:28 AM
Dud you are a freaking machine!! Congratulations on the new garage! It sounds SWEET!
For your next vacation you need to drive that STS! That's the best wa to create projects, although with your level of maintenace that may take awhile!
N*Caddy
11-19-12, 01:27 AM
Ok I went outside and took some pictures and made a clip.
Here are the switches (I went with stainless steel frame covers and black switches/outlets and for the garage door switches I went with gray):
http://img834.imageshack.us/img834/3848/beforer.jpg
This is the before picture, see the power wires and the low voltage (controls) cables. The Orange rectangle shows the box where the light sensor controls are placed.
http://img820.imageshack.us/img820/5431/switches3.jpg
This is the same thing once I installed the drywall (painted and all).
http://img825.imageshack.us/img825/8043/switches.jpg
http://img5.imageshack.us/img5/8660/switches2.jpg
Note the gray switches (for the garage door open/close), as you see are regular Leviton switches. I was unable to find momentary switched in this format (only for doorbell) so I modified the regular switch adding a spring that transforms it into a momentary one. At some point I will add an LED in the switch (just like the regular door switches have).
http://img59.imageshack.us/img59/948/bracketam.jpg
This is the "designer" garage door opener bracket (I can hang easily 400 pounds on it - TESTED!).
In there I will place the web server and a car battery charger.
And this is the final result :):
http://youtu.be/GKhcQdJZGc8
Note I am in the car on the driveway in front of the garage. On the top right corner you see the amber light (that is the light on the HomeLink when I press the button). Then you see the garage door opening and in the same time the exterior lights turn on. During the day the same thing happens just the lights stay off.
Oh…I am also looking for a 20 gal air compressor, it will be installed in the attic - lots of work left.
As for driving the STS, next week Jake will take possession of it for a bottom end seal while the tranny will be sent to the tranny shop for a full rebuild.
Next summer I decided: US Epic Journey Part II: Ontario-Michigan-Minnesota-North Dakota-Montana-Idaho-Washington-Oregon-California-Ariziona-Utah-Colorado-New Mexico-Oklahoma-Kansas-Missouri-Arkansas-Tennessee-Kentucky-West Virginia-Ohio-New York-Ontario). That should left me with Rhode Island, New Hampshire, Vermont, Main and Alaska as the only states left unvisited with the Caddy. I guess the New England states can be done over a long weekend…Alaska…I can’t stand cold weather anyway.
Submariner409
11-19-12, 09:46 AM
Has anyone gone back in time in CF and read up on N*Caddy's epic 11,000 mile non-stop trip in the STS - counterclockwise around the U.S. border a few years ago ? This is the guy that makes all his LED bulbs and lamp assemblies by hand.
N*, Check this out for your car wash buckets made from drywall mud buckets - they work and work well: the sheer amount of grit that drops out of your wash mitts will scare you big time.........
http://www.gritguard.com/
(http://www.gritguard.com/)
thebigjimsho
11-19-12, 11:37 AM
I've been wanting to do a trip like that for years.
talismandave
11-19-12, 06:26 PM
One of the sat morning car shows did a demo of those grit guards washing a fiarly clean car a while back and it was shocking how much was in the bottom of the bucket when they were done.
vincentm
11-19-12, 07:14 PM
If you drive down WA, lemme know where and we can meetup
talismandave
11-19-12, 08:22 PM
N* you got mad electronic skills! Really cool.
My kilt wearing friend at work is about the same. Offered to custom LED my Cadillac tail lights just to learn how, and is designing a plastic melting system to take bottles and shrink rap and turn it into extruded rod to be used for fastening and filling materials.
One question. It has been 20 years since I have been to Toronto, I came several years in a row in the 80's. Is it still as beautiful, clean and relatively crime free as it was? We were amazed to ride the underground and find no vandalism or graffiti! One year we arrived during a huge fair to find no rooms available and slept in a park. Police came by and told us it wasn't allowed but to come back after 11p and we would be fine they stopped checking after that.:lol: We were always impressed with what a great and friendly city it was.
N*Caddy
09-18-13, 10:32 PM
Well since last year I got my own 20gal-air compressor, lot more tools (including torque wrench, air tools - like paint gun), I painted once more the garage interior and both the front and rear doors.
http://img94.imageshack.us/img94/1783/ii1c.jpg
On the rear door glass I added some frosting film and made 2 strips on it.
Then I added a hatch to the attic opening
http://img40.imageshack.us/img40/9990/uy6b.jpg
And now I am adding art to the walls:
http://img23.imageshack.us/img23/6517/xinh.jpg
http://img9.imageshack.us/img9/5114/twyu.jpg
The Caddy was in most of the state on this wall and the goal is see all (with the possible exception of Hawaii).
orconn
09-18-13, 10:56 PM
I always wanted a wash bucket set up with a mechanical wringer attached, but never got around to getting one. I was going to offer you a Virginia license plate but I see you already have one.
CTSCHICK
09-18-13, 11:05 PM
Nice compressor is that real SnapOn one or one of the Costco super store licensed relabeled ones?
N*Caddy
09-18-13, 11:29 PM
Is a Costco bright red 20gal Air compressor with a Snap On logo on it, in the small booklet you receive with the compressor is stated (in more elaborated words) that you bought a Snap On billboard. But so far so good, I have a HVLP spry gun and I painted the house doors, the garage doors, a privacy fence in the back, I can fill up my tires, blow air to clean stuff. As long as you understand is a light duty compressor (not supposed to run continuously) is pretty good, definitely for what I do in weekends in the 2 months of summer we have here is fine. The main reason I bought it is, believe it or not, winterize the sprinkler system. One thing I have to complain, is God damn loud, I mean for the size should be way quieter.
As for license plates I am now looking for Canadian license plate set from all provinces and territories, plus a DC license plate with “Taxation without representation” logo, I also want a Cuban and a Costa Rica license plate. I am looking among others for a genuine Stop sign (24”) and an 85MPH speed limit sign. Oh yeah Interstate signs for I95, I80 and so on...and one of those vintage "Cadillac Authorized service" round blue signs.
http://garageart.com/images/prods/2616.jpg
CTSCHICK
09-18-13, 11:41 PM
Most people would never know the difference anyways.
If it is to loud they make silencers for air compressors.
CadillacLuke24
09-19-13, 12:05 AM
Holy crap dude. I have serious garage envy.
Nice job! :thumbsup:
talismandave
09-19-13, 12:26 AM
Coming along nicely. :thumbsup:
