: 3.0 L Exhaust
clydej11
06-30-12, 12:41 PM
Looking for exhaust ideas for my 2011 cts 3.0L sedan , single or dual exhaust
Panzer Leader
06-30-12, 06:57 PM
Same thoughts that I am having, wonder if the 3.6 dual exhaust can be modded to fit. The only thing would be to remove the rear diffuser under the rear bumper and attach one from the 3.6.
clydej11
07-02-12, 09:07 AM
You can put a 3.0l exhaust on it tho can't ya?
Panzer Leader
07-21-12, 11:31 PM
3.0 is a single exhaust. 3.6 is the dual exhaust. The current 3.0 single exhaust is on the left side. Question is how would you get the 3.0 left side bends right, to modded for the right side? In the long run the 3.6 OEM dual exhaust would be the easiest way to go. KBE makes axle backs for the 3.6 but nothing for the 3.0. I guess you could use 3.6 OEM and replace the OEM axle backs with the KBE.
clydej11
07-23-12, 12:15 PM
Ya but what about keeping it single is the a muffler out there that would sound good with just the one muffler ?
Panzer Leader
07-31-12, 06:52 PM
Possibly but why? If you re going to modify the exhaust I would do the dual exhaust, add the CAI and the plenum spacer. Should see some gain in HP and Torque. That is my plan of my 3.0. Though, I understand that a supercharger and turbo are possibilities as well.
Jazfreek
08-22-12, 07:56 PM
I have an '11 Sports Wagon and I took it to a custom exhaust shop today and had a chance to look under the car. The 3.0 has an awful dual exhaust under it. The tech said it was very restrictive being that it's only an inch and five quarters in diameter.
I did some research and found that Magnaflow makes an exhaust. The part number is 16831.
tinman
08-23-12, 01:25 PM
Inch and 5/4? You mean 2-1/4"?
lowlowe
09-12-12, 12:38 AM
I am in the process of installing the MagnaFlow dual on my '12 CTS 3.0 w single exhaust. It is not the easiest, as a bracket needs to be welded in on the right side to hold the back of the muffler up (along with cutting a hole in the rear lower valance for the tip). Also, needed to buy are the rubber "hangers" from the Caddy Dealer (parts need to be shipped in from Lansing, MI) to make sure the two pipes hang at the same level. I have been driving around for 2 days with a brand new CTS (600 miles on it) with one muffler on and one off basically at the cat. It sounds like a fart in a tin can right now, and I am pretty sure people think I am some punk kid who thinks it sounds great. I just need the bracket welded on, but no time until the weekend to weld it up.
tinman
09-12-12, 08:46 AM
Too bad you don't live in Jax.
Jazfreek
10-02-12, 09:35 PM
I just had a Magnaflow exhaust installed on my 2011 Sportswagon AWD. I found it $670 shipped and it sounds pretty nice.
traveler1
11-04-12, 11:38 AM
I'm looking to put 3.6 dual exhaust on 2011 cts 3.0, also. what about the warranty , will the change effect that.
