: matching belts
06-26-12, 05:32 PM
I bought two belts that go around the compressor and power steering pump and when I got home I noticed the packages have slightly different measurements. One is 13/32" x 60 1/8" and the other is 3/8" x 60 1/8". Measured in MM one 1525mm and the other is 1526mm. That small difference should be fine right? the teeth on both belts look different too.
06-26-12, 05:59 PM
If all your pulleys are cut for two V-belts on each accessory you MUST use the same - exact same - belts. While the same part number is OK, a few belt manufacturers package belts in matched pairs.
Take a hard look at one of my marine engines that I built - the belts are a matched pair from Gates. At least get the same top width belts - that should be easy.
